Old 15-10-18, 01:37 PM   #11
650
650's Avatar
Default Re: Another USD thread
Hence Maxton - they'll do an infinitely better job. I know, I've used them.
Not cheap though, by any stretch of the imagination. So if Bibio can suggest mixing oil weights to come up with something suitable (I'd be all ears for this) then that'd be worth an initial shot, along with springs designed for your weight (linear!)
93 VFR750 - WAY too many mods to list. Crashed
04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC
650 is offline   Reply With Quote
Old 15-10-18, 01:53 PM   #12
i wish it were that simple as just mixing oil weights.
the first thing you need to do is recognise what the problem is FIRST before you can rectify it. for instance is it fast rebound, slow compression etc.etc. once you know whats wrong then its a case of altering the shim stack and oil viscosity.
oil viscosity is easy as you just mix till you have the correct rebound when the adjuster is in the middle of its range. this alone wont fix other problems.
its a very long and slow process that requires the correct tools.
Old 15-10-18, 02:44 PM   #13
650
650's Avatar
Haha, that's me out then. No idea - it either goes round corners as I want it to, or it doesn't. If it doesn't, I usually just pop the front end off to Maxton and have them work their magic. No amount of fan-dangling on my part will ever, ever come close to their ridiculous expertise or workmanship.
Old 15-10-18, 03:01 PM   #14
zsv650s
unless your racing all the time k-tech are a waste of money. they are not designed for the road.
you would get better results mixing oil viscosity and shims.
the last thing you want for road use is hard suspension.
hey bibio I am 6ft and about 105kg (of pure muscle honest) so it could use being quite hard.
zsv650s is offline   Reply With Quote
Old 15-10-18, 03:10 PM   #15
650
650's Avatar
It's not about hard/soft (that's what she said). It's about the springs suiting your weight and the valving suiting your riding style.
Use this for spring rates: http://www.racetech.com/VehicleSearch
Old 15-10-18, 03:31 PM   #16
zsv650s
Still Not got a clue I just point it and go leave that kind of witchcraft to the experts.
Old 16-10-18, 07:41 AM   #17
650
650's Avatar
haha, that's the best option in my eyes. If you've got the money (between £800 and £1300 ish) then I'd highly recommend a front revalve and a new adjustable rear shock from Maxton. They really are the dogs danglies. It seems like a bit outlay, but if you keep the bike for any significant amount of time, it's worth every penny.
9/11 Discussion Thread - Split from 9/11 respect thread Berlin Idle Banter 76 15-09-12 08:32 AM
The "question Scoobs' sexuality" thread (aka the real Xma get together) NB: this thread title is extremely long isn't it? the_lone_wolf South & West Surfers 69 25-11-10 11:45 AM
