Went in to Steve Jordan's workshop today to ask about a remap, and wondered if there was anything else they could do to smooth the throttle response. The mechanic suggested I should have the throttle bodies balanced. The bike is due it's 4000 service. Are they likely to unbalanced? I have a stock bike, and a hindle full system. Would having unbalanced bodies make throtle response jerky? Is there any way to tell if they are unbalanced by riding it or listening to it?
Thanks in advance! John |
#2 | |
The Sick Man
Whats that other mod you can do to the throtle bodies on the FI bikes. The one that sync's the ECU with the TB? You need to do the dealer mode then move something and look at the speedo. Im not sure but someone will be.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#4 | |
hmmmm.... i need to invest in some of those |
Hi, if you look at the snappy engine thread I had the same problem with my k3 it turned out to be the tp switch on the throttle requiring setting up.loads better now.
#6 | |||
They could be out of balance, but they probably won't be by now. The tp switch is the best place to start, though. It's a ******* to do but definitely worthwhile.
Throttle bodies aren't difficult to balance, though, and worth at least checking now and again. |
I had been told by some people that changing the TP switch didn't make much difference, but I'll do that too I guess!
#9 | |||
#10 |
Got a full set if you need to borrow them
sync throttle bodies | olden mgroin | SV Talk, Tuning & Tweaking | 5 | 29-09-08 07:41 PM |
lets talk wheel bearings. | Warren | SV Talk, Tuning & Tweaking | 11 | 13-09-06 12:25 AM |
lets talk RF ariels and antennia | Warren | Idle Banter | 20 | 21-08-06 08:03 PM |
Lets talk about bike comms | stewboy | SV Talk, Tuning & Tweaking | 16 | 27-01-06 07:27 AM |
lets talk service | Warren | Bikes - Talk & Issues | 9 | 16-05-05 04:06 PM |
