12-08-10, 06:53 PM | #51 | |
Re: I need training...
Im not about doing 80 on every road on every corner, just wanna be mid pack rather than towards the back if you know what i mean. Like i said earlier, it is more mental, once i feel comfortable at speed under a big lean it will take away the uncertantly and allow me to focus on other stuff. |
12-08-10, 06:55 PM | #52 |
So you know problem, go sort it. Only way you get this is by practice at what you need to do.
Track will be great for that. Or, dare I say it... go ride the fackin bike!
12-08-10, 06:58 PM | #53 | |
In fairness, i do ride as much as i can, but feel i have reached a plateau and need help to go further. |
13-08-10, 06:51 AM | #54 |
Progress!
So it looks like its the relationship (or lack of) between what you are seeing as vanishing points and the mental link in throttle position and brakes. If you like, your "ride by wire" system is switching mode on smaller roads. Its going from normal to rain mode! Or even to broken mode! This relationship usually develops with time and experience but something has happened to alter the relationship between vanishing point and throttle position and and brake in these situations that you find uncomfortable and this leads to nervousness (which then closes the loop and the more nervous you are the more the relationship is affected) And I'd suggest that a track session will allow you to "recalibrate" this relationship and should build your confidence that the system can be recalibrated. Cadwell and Oulton are probably the best places as they most resemble the roads that are causing the problem. Vanishing points everywhere on small, narrow roads with trees and hills. A Novice session with an instructor at either of these tracks would allow you to increased the rate of application of your "ride by wire" relationship between vanishing point and throttle/brakes. The idea of the track day is NOT to see how fast you can go around the track but how smoothly. Repetition of smooth will recalibrate your Sight/Action relationship and should lead to a better transfer once you are back on the road. You need to recalibrate your resudual muscle memory so when your mind sees X it gets used to doing Y subconciously. Its a bit like adaption to a Race configuration gearbox. Everything is reversed and it takes time for the body to accept that the new system is the norm. But it should be easily achievable in a day. (I've been coaching for about 11 years and love this stuff ) C |
CBT Training | SAMMY650 | Pennine Massive | 2 | 21-06-09 10:26 PM |
CBT and DAS Training | metalmonkey | Bikes - Talk & Issues | 3 | 09-04-09 02:10 PM |
dog training | leemole | Idle Banter | 8 | 28-10-07 11:18 AM |
First Aid Training | Fizzy Fish | Bikes - Talk & Issues | 9 | 24-09-07 11:54 AM |
DAS training. how much? where etc | kjames | Bikes - Talk & Issues | 67 | 28-08-05 07:59 AM |
