Old 19-03-17, 09:38 PM   #1
McTav
Default What is this part called? (Indicator related)
Hey guys,
I managed to drop my bike this morning...
The front left indicator snapped off, the indicator itself is okay, but the bit that holds it on to the fairing is broken.
I can't find any replacement parts as I'm not sure what it's called.
Will that part be included in most replacement indicators, such as this - http://www.wemoto.co.uk/bikes/suzuki...te_front_left/ ?
P.s. I'm tempted by getting some LED's whilst I have to replace an indicator anyway. Would they come with the mounting bracket thing for them?
Old 19-03-17, 09:54 PM   #2
DuncanC
Default Re: What is this part called? (Indicator related)
That is part of the indicator, you won't be able to get it on it's own. The world of aftermarket indicators awaits. If you go down the LED route you will need either a new relay or ballast resistors to make them work correctly.
DuncanC is offline   Reply With Quote
Old 19-03-17, 10:00 PM   #3
McTav
Okay, so it'll come with any OEM indicator unit? Perfect.
Old 20-03-17, 08:57 AM   #4
daktulos
daktulos's Avatar
Be careful with this - I don't know which model you need the part for, but if you look at the parts list (e.g. this one):
https://www.fowlersparts.co.uk/parts...gnal-lamp-note
Part 8 is the lamp assembly which I don't think includes the bit you want. I can't tell which bit you need, but some of them are in stock - e.g. part 13.
daktulos is offline   Reply With Quote
Old 20-03-17, 09:16 AM   #5
ophic
ophic's Avatar
No, you'll need some spacers - sort of teardrop or coffin shape bits of plastic, as aftermarket indicators just use a bolt. Or you could probably get away with large repair washers with maybe a bit of filing.
googling "suzuki indicator spacers" shows plenty of hits of what I mean.
Just to be clear, these are to fit aftermarket indies and won't replace the stock part.
Silver SV650SK3, Fuel exhaust
Old 20-03-17, 09:25 AM   #6
McTav
Thanks for that, I hadn't seen this site before.
Aren't spacers for, spacing? So they fit on the same side as the indicator unit, whereas I need something on the other side of the fairing?
Old 20-03-17, 10:50 AM   #7
ophic
ophic's Avatar
They convert the odd shaped fairing hole to a round hole to take an aftermarket indicator. I think you need one on each side of the fairing hole - so 2 per indicator.
I didn't choose the name but I can't think of a better one
Old 20-03-17, 07:48 PM   #8
Indy Spacers is what they're called
https://www.rydestore.com/ryde-suzuk...DNMaAsAX8P8HAQ
Whats this part called? JohnStMartin Bikes - Talk & Issues 2 02-09-15 07:28 PM
What's this part called? chuck43 SV Talk, Tuning & Tweaking 10 27-04-12 10:21 AM
What's it called? (Pointy part enquiry) Baph SV Talk, Tuning & Tweaking 2 05-12-08 09:18 PM
Whats this part called? stephencassidy SV Talk, Tuning & Tweaking 4 29-04-07 02:57 PM
Anyone know what the green box electrical part is called? lockery SV Talk, Tuning & Tweaking 14 15-04-06 09:00 AM
