Old 09-04-19, 02:03 PM   #1
Seeker
Seeker's Avatar
Default decorating
I'm decorating my dining room, it was papered. I've stripped the paper and found the walls were previously painted -red on two walls, white on one and yellow/gold on another (yikes). Most of the big areas of paint have been removed when the paper came off but there are still a few largish patches.
My plan is to repaint with a textured paint which I've bought (Crown Suede). I scraped and sanded the walls, filled the holes, sanded again but everytime I turn my back I see a bit of paint that is starting to flake despite having been previously scraped.
It's like being exposed to air is making the old paint catch up with its age. Out of curiosity, I sanded one spot, scraped it again - no loose paint. 30 minutes later there was an edge starting to lift.
I wonder if I leave it long enough it will all fall off
Old 09-04-19, 04:09 PM   #2
Default Re: decorating
Old 09-04-19, 04:33 PM   #3
Talking Heads
You're finding out why it was papered...?
Best solution... paper it again.
Talking Heads is offline   Reply With Quote
Old 09-04-19, 08:43 PM   #4
zsv650s
This x100 if they are really bad try wallrock fibreliner.
zsv650s is offline   Reply With Quote
Old 10-04-19, 07:19 AM   #5
Seeker
Seeker's Avatar
I put 65 grade sandpaper on my sander and it's doing the trick - I've got 90% of the walls done. I also discovered that hooking up a vacuum line to the sander, as the manufacturers suggested, makes an immense difference to dust levels.
Pity, I didn't do it until after the dust has spread around every room in the house.
Gypsum is natural so it's good for you, right?
(Public Service Announcement: do not inhale gypsum dust)
Old 10-04-19, 07:30 AM   #6
I hope you used an old Hoover. That stuff destroys them
Old 10-04-19, 08:37 AM   #7
Seeker
Seeker's Avatar
I have a Dyson which is on it's last legs and an Electrolux which came off the Ark.
Old 10-04-19, 10:58 AM   #8
Adam Ef
Adam Ef's Avatar
We were finding dust from sorting our walls out everywhere in our house for years after I did the work. We had similar. Walls held together by the paper. Thick, textured, pink and purple paper.... everywhere!
Past:
Old 11-04-19, 08:44 PM   #9
SV650rules
I have always preferred painted walls to paper, but in some houses the paper was on to keep the walls together, and in one house that had been papered, then the paper had been painted, then papered over and then painted ( this had been repeated about 6 times ) and trying to get paper off and back to bare plaster took forever......
You need good walls to look good just painted...
2016 SV650 AL7
OMO: Ladders for decorating stair wells -Ralph- Idle Banter 8 05-03-12 03:23 PM
Decorating ideas please Ed Idle Banter 13 04-01-11 09:27 AM
Decorating/interior design ideas: Resources and help Paul the 6th Idle Banter 22 15-10-08 01:16 PM
Not very interesting Decorating question Kate Moss Idle Banter 9 19-11-07 06:20 PM
