10-12-12, 03:34 PM | #1 |
Front fork spring washer - where from?
hi just took forks apart to do oil change , and i havent got a spring washer in the one iv just done , looked at manual and it says there should be one , checked the bowl i put old oil into, and its not there , the last time my oil was done , it was done by a garage , but thought id do it myself this time , does it matter if there isnt one in it , if it does , do you know where i can get one from , its for an sv650s , all standard shocks , would like to know befor i go putting it back together ,
thanks for your help again |
10-12-12, 06:14 PM | #2 |
Re: frount fork spring washer
shirlaws should be able to sort you out.
10-12-12, 06:22 PM | #3 |
be cheaper buying a new shock than i would for a washer from shirlaws lol
11-12-12, 09:48 AM | #4 |
Re: Front fork spring washer - where from?
robinsons foundry perhaps
Or could you take a look at the one in the other side and compare an off the shelf one from an engineering supply place?
11-12-12, 09:53 AM | #5 |
11-12-12, 12:15 PM | #6 |
put order in to robsons last night forgot about them , thanks , elliot its not that bit im after , its the spring washer that sits on top of spring inside fork , didnt have one when i did oil change in forks , but manual says there should be one ?
thanks again for your help |
Fork retaining washer 51158-05A00 | beabert | Stuff Wanted | 0 | 08-07-11 06:13 PM |
fork spring spacers | neillyg72 | SV Talk, Tuning & Tweaking | 3 | 20-03-10 12:51 PM |
Fork spring upgrade | Mark_h | SV Talk, Tuning & Tweaking | 6 | 25-07-07 08:32 PM |
Fork Oil and Spring Overhaul Kit | shelleyamy | SV Talk, Tuning & Tweaking | 14 | 27-06-07 07:48 PM |
Fork spring question.... | Junior | SV Talk, Tuning & Tweaking | 4 | 07-01-05 09:20 AM |
