Old 05-02-18, 12:28 AM   #1
Muel
Junior Member
Default 2004 GSXR 600/750 Front End Conversion
2004 GSXR front end, includes fork legs, yokes, headstock bearings, calipers with worn pads (some life left), wheel spindle.
Pulled from a working road bike. In regular use before removing, only removed to swap to a black front end. Headstock bearings will fit SV650 pointy frame and lockstops and steering lock line up.
Generally in good condition, both legs are dead straight. One fork leg has a ding and dust seals look fairly rough (see pics), but the oil seals don't leak and the forks slide cleanly.
Price is £450 collected from Sheffield, all offers considered!
Muel is offline   Reply With Quote
Old 06-02-18, 09:32 PM   #2
650
650's Avatar
Default Re: 2004 GSXR 600/750 Front End Conversion
Hey, bit off topic - could you measure from centre hole to fork cap...there's some debate on the actual length of these forks. I may well consider them if they're as long as suggested.
Thanks
93 VFR750 - WAY too many mods to list. Crashed
04 SV1000 - Bar end mirrors. Belly pan. Seat cowl. K4 GSXR600 K6 front end and custom top yoke. R6 Brembo MC
650 is offline   Reply With Quote
Old 07-02-18, 05:58 AM   #3
Muel
Junior Member
Thanks
Howdo, center hole of the the spindle? And which part of the cap? Where the silver face meets the top of the leg (so the join that you generally set flush with the top face of the top yoke) or the top of the adjuster?
I've got a K8-10 600/750 front end I can also measure to compare if that would help?
Old 07-02-18, 09:51 AM   #4
650
650's Avatar
Yeah, spindle center hole to where the fork tube meets the cap My K3/K4 1000 front end will be up for sale soon so I want to see, in reality, what the length differences are. I'm looking at the k6/k7 600/750 front end as that's the nearest to stock length (again, apparently, no absolute confirmation anywhere). I'm thinking your forks in this ad will be 720mm (or there abouts).
Thanks in advance!
Old 08-02-18, 11:08 PM   #5
DryRob
Does the standard pointy front wheel, grips and brake levers fit this? Would the speedo need adjusting?
Sent from my SM-G903F using Tapatalk
DryRob is offline   Reply With Quote
Old 09-02-18, 01:08 PM   #6
Nope
You need a gsxr front wheel and discs, plus handlebars. All the handlebar controls will fit.
To make the Speedo work you'll need a Hall effect sensor, plus magnets mounted in the disc brake rotor.
Do a search on here, Google or Sv rider.com, plenty of articles about it.
Old 09-02-18, 02:01 PM   #7
650
650's Avatar
Nope
Actually, any SV1000 wheel will fit...often cheaper to buy, too. The wheels are comparable fitment for all 01+ GSXR. Only the spindle changes - I think from 2010 onwards the wheels aren't quite so easy to fit.
So to make it easy, buy ANY SV1000 front wheel and spindle - the SV1000 discs are 310mm if memory serves me right. Bear in mind disc sizes, spacers may be required for the calipers. ...Job's a goodun.
The de facto information post about this is here: http://www.svrider.com/forum/showthread.php?t=135430
Old 09-02-18, 02:04 PM   #8
Good point, although a 650 Pointy wheel won't fit
Old 09-02-18, 02:07 PM   #9
650
650's Avatar
That's what I'm saying - albeit in a daft roundabout way, haha
Old 09-02-18, 02:10 PM   #10
I knew what you's was getting at
GSXR Front end conversion -SOLD Vergey For Sale - Other Bikes and General biking items 17 14-08-11 11:47 AM
GSXR front end conversion using SV front wheel maviczap SV Talk, Tuning & Tweaking 24 13-03-10 02:06 PM
SV GSXR front end conversion for sale PURPLE For Sale - SV's and SV related items 12 07-08-09 10:19 AM
SV GSXR front end conversion tiernanobrien SV Talk, Tuning & Tweaking 16 19-07-09 02:29 PM
