02-02-12, 01:19 PM | #1 |
Pointy running questions.
HI all,
First time i'd had to ask technical questions on this board whih isn't bad considering i've had the bike since Agust. Anyway: 1. Are SVs known for burning a bit of oil? admittedly i hadn't checked it for a while but it as pretty low when i did the other day 2. Since this cold weather has come along, the bike struggles with idling initially when i first set up. I always let the bike warm up whilst i get jacket/gloves/helmet etc on and i idles nicely at about 1400 - 1500 When i set first off, sometimes i pull to the end of the road, pull clucth in and the revs drop to about 1000 then the engine dies. I would have thought the ECU would keep the idle a bit higher. Does the bike have an idle control valve as i know they can get drty and play up from time to time. cheers D |
02-02-12, 01:28 PM | #2 |
What year is your bike?
02-02-12, 02:06 PM | #3 |
Re: Fe questions
my bad, 2003 faired
02-02-12, 02:43 PM | #4 |
Re: Fe questions
yes they can consume a bit of oil depending on mileage and usage. seems to be the more you thrash it the more oil you use.
how does the bike tick over when fully warm? could be a case of just turning up the tickover a tiny bit. no proper ICV till twin sparks 2007> |
02-02-12, 06:24 PM | #5 |
Re: Pointy running questions.
The idle is too high at 1400-1500, it should be about 1200ish.
Check: Throttle balance TPS setting STV idle setting. Any, or a combination of all, of the above will cause the problem you're describing, the earlier FI systems have no discrete ICV - fortunately. Don't let it warm up on the stand, ride it straight away, no thrashing 'til it's warm obviously. Many SVs use a bit of oil, I suspect that most of those were too cautiously run in.
03-02-12, 07:42 AM | #6 |
Trinity
03-02-12, 09:25 AM | #7 |
03-02-12, 09:38 AM | #8 |
Not on K3, they have manual fast idle.
03-02-12, 12:13 PM | #9 |
There was a threat about warming up first not long ago and generally it's better to just ride off straight away as it uses less fuel and reduces wear. As SS said just take it easy until normal temp is reached (P) or you no longer need choke (C).
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers |
03-02-12, 03:16 PM | #10 |
Ok cool. I always take it easy until its nicely warmed up anyway. I suppose the warming up theory is quite an old school one.
Pointy misfire and running problems. | tom-k6 | Bikes - Talk & Issues | 3 | 16-05-11 09:55 PM |
Pointy SV won't find neutral when running | skithepowder | SV Talk, Tuning & Tweaking | 4 | 12-02-11 06:24 PM |
Pointy running poorly. | timbuk21980 | SV Talk, Tuning & Tweaking | 23 | 02-02-11 04:30 PM |
Bandit 1250, S3, B-King running cost questions. | ethariel | Bikes - Talk & Issues | 13 | 12-04-09 07:15 PM |
running questions | zsv650 | Idle Banter | 4 | 11-04-09 06:28 PM |
