Old 12-06-15, 11:28 AM   #1
Aligowers
Default Curvy grinding when pulling away in 1st gear.
Hi folks my 02 sv is grinding sometimes when i pull away. It only happens sometimes and only for the first gear and for ten mins of riding then goes away. I leave the choke on for about 30 seconds when im getting my gear on and then when i put it into first and go to pull out my drive im getting a grinding sound. I also happens when im pulling of from the lights or at a junction. But only for about the first 10 mins of riding. Any ideas whats going on ? Am i not giving the bike long enough to heat up after 5 mins of riding i thought it wouldn't be an issue with the temp of the bike but im out of ideas.
Old 12-06-15, 12:00 PM   #2
Corny Gizmo
Default Re: Curvy grinding when pulling away in 1st gear.
Id first be checking your rear brake, sounds to me that the pads are dragging initially then maybe moving away from the disc (or just not making the noise anymore once you are up to speed)
Old 12-06-15, 12:02 PM   #3
Corny Gizmo
Best way to check is try not use your rear brake for a 10 min ride, stop get off and touch the disc, If your hand melts, its dragging
Old 12-06-15, 12:53 PM   #4
Aligowers
Hi thanks for the reply and advice. Ive just fully serviced my rear brake and its not dragging at all. I have checked it just now and its fine. I think it may be my clutch as if i slowly let the clutch out in first it pulls away fine with no grinding noise at all. Its only if i give it some beans when im pulling off. Ive checked my chain and its fine. My clutch adjuster at the throttle was a little bit lose. So ill check it again see what happens.
Old 12-06-15, 04:53 PM   #5
wheel bearings?
low oil level?
Old 12-06-15, 07:28 PM   #6
Biker Biggles
Biker Biggles's Avatar
Clutch.My son had the same on a high mileage curvy and it was a bearing in the clutch release mechanism.It would make a nasty noise on letting out the clutch,more so if giving it some welly.
Still got the engine if anyone wants it
Old 29-06-15, 12:09 PM   #7
Jason H
Jason H's Avatar
Also check your front sprocket and nut are all the way done up and havent statred to undo themselves and eat into the Clutch lifter/worm-drive.
J
Naked K5 - Now Red with sexy stripes!!
Mods: Renthal Flat bars, 's' clutch perch, GSXR front master cylinder, CNC shorty levers, Tail Tidy, Fuel Mini S/S Slip-on, 15/47, 's' Swing-arm, Pillion seat cowl, GSXR 750 front end, CNC polished top yoke, R6 Throttle tube, GSXR rear shock
Jason H is offline   Reply With Quote
Old 30-06-15, 08:45 AM   #8
jambo
jambo's Avatar
Clutch release bearing sounds like a candidate.
James
Grinding when first starting out al88 SV Talk, Tuning & Tweaking 4 17-06-11 05:44 AM
grinding noise Wideboy Idle Banter 11 06-08-09 01:59 PM
gears grinding KillaSV SV Talk, Tuning & Tweaking 1 16-03-08 07:39 PM
Baph goes peg grinding... Baph Bikes - Talk & Issues 24 12-04-07 05:46 PM
Grinding 1st!! Spider SV Talk, Tuning & Tweaking 9 02-01-07 02:50 PM
