Old 14-05-08, 10:01 AM   #1
svsdutch
Default removing secondary throttle valve's
just wandering,
did anybody did this?
can't find a tread about it?
on the v-strom forum(similar engine) there's a lot of writing about it.
Old 14-05-08, 10:26 AM   #2
OldBoy
Default Re: removing secondary throttle valve's
Originally Posted by svsdutch View Post
just wandering,
I very much doubt that this would work, theres a position potentiometer connected to the secondary throttle for a start. Removing it would give you a F1 fault code and if Suzuki did'nt think it nessesary they would not have gone to the expense of putting a secondary throttle on.
Old 14-05-08, 10:43 AM   #3
If it is indeed possible then the fuelling will be well sharp. It is analogous to slide carbs, direct control of airflow...
However, with the injection, unlike a slide carb, it will still get its fuel fine if you bang it open, unlike the slide carb which does not get vacuum if whacked open and stutters or dies completely.
P.s the SV carbs are CV type carbs which use a vacuum operated slider to avoid this.
IMO the easy way to do it is just take the butterflys off the spindles.
Removing throttle bodies muffles Bikes - Talk & Issues 4 19-04-09 12:50 AM
removing throttle tube?? arcdef SV Talk, Tuning & Tweaking 6 23-01-09 11:06 PM
Secondary Arthritis dizzyblonde Idle Banter 23 30-04-08 06:08 PM
removing fairing silent11 SV Talk, Tuning & Tweaking 2 24-03-08 08:08 PM
Secondary Throttle Plates, who needs 'em!? TheLeprechaun SV Talk, Tuning & Tweaking 11 17-05-05 09:24 PM
