Old 09-10-17, 06:26 PM   #21
DomP
Default Re: Fork value
Originally Posted by PyroUK View Post
Pretty normal up till about 6 6 and half then the exhaust opens up and it's a sweet whistley note
And when you chuck a quick shifter on, the fun is almost too much
Sent from my SM-G950F using Tapatalk
I've been looking at one in Newport, it's a 2006 and they'd give me 1600 for my sv. Just need to sell my clio 182 as well to fund it because I rarely use it now I run around in a van.
What's the upgrade to a 675 like? Are there any things to look out for with Trumpets like corrosion or are they better than suzuki sv in that department?
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired
White 2011 YZF R125 sold
DomP is offline   Reply With Quote
Old 09-10-17, 06:41 PM   #22
PyroUK
PyroUK's Avatar
I'll be honest I'm not too sure, I jumped in to mine without doing any research!
In hindsight I would have looked around a bit more for a similar age 675r, you get the ohlins and brembo.
However I've had the suspension set up and upgraded the brakes and fitted a quick shifter.
I think there's a slight bump in power for the 2009 onwards and as I said before the plug and play quick shifter.
Compared to the sv it doesn't feel a million miles off like a 600 il4 can, they're very svelt! Almost like sitting on a 125, the sv actually feels big in certain respects against the Tona!
Much like the sv you get torque for days, however the jump in power means you get a lot more acceleration and it's nice and smooth.
It revs a lot higher too, think the gen 1's redline at 13.6k or something so you're looking at 140mph+ easy. And I do mean easy, the sv is quick up to say 70ish but as with all the "big" bikes the Tona is quick in to triple digits!
I think something to keep an eye out for would be the headers, they can crack at the welds and make a weird rattling sound. Mine are and I really need to get them looked at soon.
Other than that as long as it's well maintained I think it's just the same general things as any bike. From what I've seen on mine so far there's less cheesium used but that's not to say it's not got any
Got any local you can test ride? The 06-12's are very similar aside from the points I mentioned but the 13+ has quite a few differences.
Nowt wrong with the gen 1's but if you're looking to upgrade it etc with things like the quick shifter or custom maps I'd say look out for a gen 2.
Imo I think it looks better too, the front is a bit nicer
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 09-10-17, 06:44 PM   #23
PyroUK
PyroUK's Avatar
Oh you also get a lot more adjustment in the suspension, fully adjustable for preload, comp and rebound front and rear.
You can of course also get the internals upgraded on the forks if needed, whilst mine is set up I could do with some stiffer springs as I'm a bat fastard !
Old 09-10-17, 06:46 PM   #24
DomP
Thanks for all the info, it's very helpful. There is one about 25 miles from me but not in the colour I want but I might give it a go just to see how I feel about it.
What's the seat height like in comparison as an SV is ideal
Old 09-10-17, 06:47 PM   #25
DomP
I'm a skinny 10st and a teeny bit and 5' 7"
Old 09-10-17, 06:56 PM   #26
PyroUK
PyroUK's Avatar
Seat height is similar I think, however it's thinner at the mid point where it meets the tank so if it's a bit taller it's less noticeable if that makes sense?
It's also lighter I think.
10st! You'll fly on any big bike haha
Old 09-10-17, 07:08 PM   #27
DomP
Yeah if I has skills I'd be deadly!
Old 10-10-17, 12:17 PM   #28
DomP
Or HAD even!
Old 10-10-17, 12:57 PM   #29
PyroUK
PyroUK's Avatar
Oh also something else to consider when looking, if you're wanting an end can look for ones with them already. They aren't cheap!
Take a gander at 675.cc forum
Old 10-10-17, 12:59 PM   #30
DomP
I was noticing that, the one in Newport is 06 at £5400 with 17k and an arrow end can. Seems a little steep by comparison
Replacing fork seals and fork set up? Ricky650 SV Talk, Tuning & Tweaking 11 26-03-12 02:20 PM
Fork oil air gap ccurts SV Talk, Tuning & Tweaking 7 20-01-08 11:23 PM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
Fork Oil to do with me! Daglad SV Talk, Tuning & Tweaking 4 22-11-05 06:08 PM
