Old 18-12-06, 10:47 PM   #21
Bear
Originally Posted by TSM
When you try and start the bike, do you hear the starter relay clicking, YES
when you turn on the bike with the Kill switched off, do you hear the injectors priming? YES Any error codes on the LCD (you will probably have to put it in "dealer mode")? HOW DO I DO THAT? Explain more this noise you herd from the engine before it went all wrong. It kinda sounded like I had something sticky on one of the tyres which was making a noise as I was pulling away.
Even with the clutch pulled in or out a push start should be enough to turn over the engine bypassing the starter circuit.
Thing is it push started first time, then wouldn't do it again.
Old 18-12-06, 10:50 PM   #22
Bear
Originally Posted by fizzwheel
Umh... weird...
So with the ignition on with the bike on the sidestand, you've got an oil light, you hear the bike pressurise the fuel rail and you've got a Neutral light, but when you pull the clutch in the lights dim, the starter doesnt turn and the headlights dim.
You got it.
Old 18-12-06, 10:52 PM   #23
netsurfer
Originally Posted by Pigbunk
Sorry, I'm a little confused. It won't start unless the clutch is pulled in anyway.
It wont, which side did it go down on maybe the clutch levers a little bent and even with the clutch pulled in its not working the bypass switch properly.
Might be worth having a search for the instructions on how to bypass the clutch switch and then see if it'll start.
My point was, that if the lights DONT dim with the clutch lever out, and DO with the clutch lever in, then this proves the switch is OK
You heard the starter relay clicking so it is DEFNITLEY not the clutch switch.
Pete
Old 18-12-06, 10:53 PM   #24
Bear
Gotcha. I'll give it a go in t'morning.
Old 18-12-06, 10:55 PM   #25
fizzwheel
fizzwheel's Avatar
Umh... weird...
You got it.
OK IMHO and I'm no expert. I think that when the bike was on its side, the oil has been pumped up the crankcase breathers and into the airbox. Then when you've picked the bike up that oil has run down the airbox and maybe into the throttle bodies or what ever new fangled pointies have instead of carburettors and then down in the cylinders. Causing hydraulic lock which now means that theres to much pressure in the cylinders and the starter motor won't turn the engine over. IMHO this also explains why the bike doensnt run now when you try and bump start it.
Somebody else talked about "Hydraulic Lock" in another post in this thread. I think this is whats happened and I wouldnt try and start it again till you've at least lifted the tank and taken the airfilter out and seen whats lurking about in your airbox. If you can take the plugs out and then turn the bike over and see if it pumps oil out of the plug holes.
Like I said I'm no expert, but I've had similar problems with my SV with oil / petrol in the airbox causes similar issues where I can't start the bike.
HTH
Old 18-12-06, 10:57 PM   #26
fizzwheel
fizzwheel's Avatar
Pete
He's right you know
Old 18-12-06, 10:58 PM   #27
Bear
Umh... weird...
You got it.
HTH
Cheers fizz, I'll give that a go tomorrow. If that is what's causing the problem, how do I remedy it?
Old 18-12-06, 11:01 PM   #28
Bear
Pete
No, the starter relay isn't doing a thing. All that happens when the clutch is in and the button is pushed is that the lights dim. (Sorry, only just noticed this post!)
Old 18-12-06, 11:04 PM   #29
TSM
The Sick Man
TSM's Avatar
If you can take the sparks out and make sure the HT leads are nowhere near the holes, then you should be able to turn the engine over on the starter. Any excess oil should get pumped out. I think its unlikley, my bike has never suffered it ever and its been a fair bit on its side and does not have the cut out sensor the pointies have.
Old 18-12-06, 11:05 PM   #30
TSM
The Sick Man
TSM's Avatar
Pete
You replied to my post saying that it did click when you pressed the starter. It will only click once when you press the starter. If its rapidly clicks it would indicate a low battery.
A sad start to the day ooger Idle Banter 17 03-06-08 11:27 AM
Bad start for the day timwilky Idle Banter 13 22-04-08 09:52 AM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
yet another won't start, 01 650 mann650 SV Talk, Tuning & Tweaking 4 25-07-06 03:54 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
