16-02-09, 11:41 PM | #11 | |
Re: error code c-42
Seats off, tank up. Top of the airbox off & air filter out. From this moment on, don't drop anything down the butterflies that you can see inside the airbox. Please. Stuff a rag or something over them (dry rag, no fluff). Stand at the throttle side of the bike, with a long phillips screwdriver. There's 2 clips holding the airbox on to the air intakes, unscrew these & take the airbox off completely (you don't need to disconnect the sensors/wires from the bottom of the airbox - I find it helps get more space, but you also need to remember where everything goes). Once that's off, if you look behind the headstock (in front of where the airbox was), you'll see 3-4 connectors. Take each connector apart, and give a good dosage of WD40/switch cleaner. Take the rags off & see if it'll fire. If it does, consider yourself lucky. Put the bike back together & stop reading here. One of those connectors is Black/Red, Orange, Orange/Red, Brown wires (engine side of the connector, not the ignition side). Ignition on, check for voltage between the Orange and Black/Red wires. You should have 12v minimum here. If not, find the Orange wire in the fuse box, take that fuse out. Do you have 12v here? Assuming you do get 12v to the ignition connector, check the other side of it for continuity (Red + Orange wires). If you don't have continuity, then either the wires to the ignition or the ignition itself needs replacing. If all that's OK, the front plug gets spark first. So that coil is powered first. Change the coil/HT lead/plug cap from the rear cylinder to the front, then try from the start. |
16-02-09, 11:47 PM | #12 |
Re: error code c-42
thanks a million baph
will do the clean and check first, then go to maplin if it dosent work (bike is only mode of transport which makes life hard!!) |
17-02-09, 02:58 PM | #13 |
Re: error code c-42
ok, i had a play.
took off the air box and had a fiddle. It was so hard to get the connectors open, could only get to one. so i checked that one, it was fine. all the others were clean and intact from the outside, the whole area is clean, tidy and well protected by tape too. so i turned it on anyway, started first time no probs, abs nothing wrong. ok... turned it off, back on, the fule pumps didnt prime again off and on again and it worked. i have no idea what to do next, any ideas? I also found a little LED light that flashes from the alarm that has corroded off, but i dont think this could be the problem, or it wouldnt have started now (started it about 3 times) cheers |
17-02-09, 02:59 PM | #14 |
Re: error code c-42
can the alarm be easily disconnected? is it as simple as pulling the plug from the loom?
If so might be worth doing just that and testing for reliability. |
17-02-09, 03:08 PM | #15 |
Re: error code c-42
17-02-09, 03:33 PM | #16 | |
Re: error code c-42
I reckon it's a dodgy connection you've got there. You'll have fun finding that. |
17-02-09, 03:36 PM | #17 |
Re: error code c-42
Yeah I agree Baph. I did notice on my bike that some of those connectors looked clean from the outside but had badly corroded connections inside them.
Hard to get to I know but worth checking. Water tends to run down the plastic tubes that hold the wires. |
17-02-09, 04:04 PM | #18 | |
Re: error code c-42
ok, had another play, now i cant get it to not work!! lol but ive found somthing out to do with the noises. when it doesnt work, there is still a small noise, which is this thing circled moving.. there is a bigger whiring noise which is what sometimes dosent work. when this noise dosent work is when the error comes. if it does work, the bike starts no problem at all. |
17-02-09, 04:06 PM | #19 |
Re: error code c-42
the one that i did manage to get to was pefect, looked new, not even the slightest sign of corrosion. but I know that dosent meen another cant be corroded!
17-02-09, 04:43 PM | #20 | |
Re: error code c-42
The whirring noise is the fuel pump. Have you dismantled the RH switch gear, check the connections on the kill switch (I'm assuming you've tripple checked the Kill Switch isn't disabling the engine. ) I'm in the office at the moment, but when I'm home, I'll look at the wiring diagram to see where the ignition system connects to the ECU so you can probe there with the DMM (but don't expect much to work with the ECU unplugged). |
Schoolboy error!! | in_your way_racing | SV Talk, Tuning & Tweaking | 7 | 27-10-07 03:54 PM |
