Old 26-06-06, 12:51 PM   #1
k3lls
Default Knocking noise in front fork
Hi, maybe this is normal but.......
I have noticed that when I go over a bump in the road of pothole i get a loud knock from the front forks. It seems to be OK in normal roads or in small bumps.
This is probably par for the course but as I am new to this, just want to make sure there is nothing more sinister..
BTW, I have a Pointy K3 with 5200 miles on the clock.
Thanks
Old 26-06-06, 12:57 PM   #2
Viney
*Clears throat*
They all do that sir
Old 26-06-06, 01:02 PM   #3
TSM
The Sick Man
TSM's Avatar
Err, yes, even my GSXR RWU forks do that, but to a lesser extent.
Old 26-06-06, 01:07 PM   #4
Viney
Really Interesting. I was riding over a gravely road at the weekend on a downward slope, and the front end was rattling away as normal, but on applying the brakes(lightly, i was on gravel dont forget), is almost stopped. So this is leading me to believe that its either, Calipers rattling, or the calipers/pads combo rattling as there wasnt enough braking to compress the forks. Its has been discussed a lot of times before with various opinions etc. Have a search.
Old 26-06-06, 01:15 PM   #5
TSM
The Sick Man
TSM's Avatar
Agree with what you are saying, i have not pinned if its the forks or the EBC pads & disk. I am weighting on the pads as they have movement in the caliper and the disks as they have a little rotational movement. I also think that the fork make a little noise due to the spring somtimes knocking the side wall. Not a major issue as the forks work fairly well but are beeing drained and re filled with oil as i know some leaked out when i installed them (someone did not do up the bottom bolt properly, not me).
Old 26-06-06, 01:19 PM   #6
My USD GSXR750 ones have a different knock "Bikes make noise", as Randy O says.
Old 26-06-06, 01:21 PM   #7
k3lls
You guys and gals are a real fountain of knowledge
Ok we have determined that they all rattle, but being an inquisitive type.... What causes the rattle??
Sorry
Old 26-06-06, 01:23 PM   #8
TSM
The Sick Man
TSM's Avatar
Sorry
Well its either the large springs that are in a SV fork, knocking on the side of the forks, or as i have read on SVrider someone had the idea that it was something to do with the headstock bearings. No one is 100% sure on an answer.
Old 26-06-06, 03:12 PM   #9
JakeRS
Yep used to worry me as most noises on my bike do, but learnt to live with it...
Old 26-06-06, 03:27 PM   #10
Or it might be some part of the damper mechanism, that's a popular suspect. Or the calipers.
knocking noise thedon1000 SV Talk, Tuning & Tweaking 22 13-10-08 08:27 PM
Knocking noise Cam_73 SV Talk, Tuning & Tweaking 3 04-08-08 07:48 PM
Clicking Knocking Noise ? mattglavin SV Talk, Tuning & Tweaking 12 10-09-07 03:09 PM
Knocking noise and front headlights bonzodog123 SV Talk, Tuning & Tweaking 6 22-03-06 02:11 AM
knocking noise from front end dmracing SV Talk, Tuning & Tweaking 13 18-02-06 09:25 AM
