Old 04-05-20, 08:10 PM   #11
johnnyrod
johnnyrod's Avatar
Default Re: Paddock stand
I don't know if Harris still do paddock stands, but I've got one and it's way better than the Micron ones, also the ones where the hooks just dangle are a pain.
Here they are, mine's the first one on the list:
https://www.harris-performance.com/p...addock-stands/
Old 08-05-20, 01:27 PM   #12
Sean_Morgan
Well, I've had a look and a think about it and ive ordered the abba stand with the front lift kit
Sent from my SM-G960F using Tapatalk
Sean_Morgan is offline   Reply With Quote
Old 08-05-20, 02:00 PM   #13
SV650rules
Good choice, once you have the basic stand you can get quite a few different kits for it....
I do find it a pain that most bikes do not come with centre stand any more, but by the time you have fitted a CAT under the bike not much room for anything else, and of course a centre stand adds to kerb weight of bike- which makers do not like ( although it is very low down weight ).
2016 SV650 AL7
Old 08-05-20, 02:35 PM   #14
Sean_Morgan
I'll add the moto glide and the swing arm removal kit at some point
Old 12-05-20, 03:58 PM   #15
Sean_Morgan
The abba stand arrived today so I'm just having a play and if I'm honest, I can see why they're worth paying a bit extra for
Old 12-05-20, 04:35 PM   #16
SV650rules
Nice one, the stand does make it easy to lift the bike up. I have marked the place on the lower crossbar where the sliding vertical ( on side opposite the lift handle ) sits, a black permanent marker pen line each side of the sliding square tube you can just see peeping from behind rear tyre. It makes it easier to set up when you put it onto bike next time. Don't be too aggressive tightening the screwed bit that goes into swingarm too much as it tries to bend the uprights and can cause weld in corner of uprights to crack - one member on here ( Think it was AdamEf ) got his mate to weld a couple of gussets in because the welds cracked.
I have put a couple of brackets on garage wall to hang stand on - nothing fancy just something like this https://www.amazon.co.uk/ST7004B-Mul...9301204&sr=8-5
Can slip some of the cheap foam pipe insulation over the horizontal bar on bracket to stop the paint on stand getting chipped or the stand sliding.
2016 SV650 AL7
Old 12-05-20, 05:08 PM   #17
Sean_Morgan
Marking it up was mentioned on one of the reviews I watched before purchase. I went round with the permanent marker before I put it away, but thanks for the suggestion, I'll have a look at the hangers
Old 13-05-20, 07:15 AM   #18
shiftin_gear98
shiftin_gear98's Avatar
Two cents.
I used insulation tape to hold the mounting adapters into the cups.
Once I got distracted by my kids as I was finishing up working on the bike, I failed to notice until I next needed to use the stand that the offside adapter must have stayed in the bike.
Alas it is road fodder somewhere.
I made another at work and have had them taped in ever since - this was a few years ago now.
As mentioned - you barely have to tighten the screw when fitting - shes not going to fall out.
Also mark up where the rear lift needs to be if you haven't already.
I also have the tyre fitting kit too.
Currently driving a Corsa....
Old 13-05-20, 05:38 PM   #19
Sean_Morgan
Originally Posted by shiftin_gear98 View Post
Two cents.
I'll sort that next time it's out. Thanks for the tip
Which paddock stand? aaron020873 Bikes - Talk & Issues 3 04-03-12 10:50 PM
Paddock stand DANINPLYMOUTH For Sale - Other Bikes and General biking items 1 03-12-09 12:38 PM
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
Paddock stand/abba stand or? Ruthja2801 Bikes - Talk & Issues 18 26-02-09 12:20 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
