17-05-20, 06:33 PM | #1 |
Fork oil options
After a lot of reading and research ive ordered myself a zx14r rear shock that I found on Ebay, and a pair of k-tech .95 springs.
I really didn't want to ask the usual "what spring/shock do I need" question so ive taken the gamble. There's a lot of information out there and a lot of it is conflicting. The bike is a 2003 650s and I'm 210lb. The only extra bit of advice I could do with is regarding fork oil, what weight oil would you recommend. I'm not planning on doing anything extreme on the bike just a lot of road work, I'm just looking for an improvement on the bouncy castle Thanks in advance for any input Sean Sent from my SM-G960F using Tapatalk |
17-05-20, 06:47 PM | #2 |
Re: Fork oil options
I want to say 15 but wait for someone else .
2 Penneth on the shock - I would consider getting it serviced before fitment. It’s out , it’s easy and it doesn’t cost the earth. I don’t know what years zx14 ran but I’m guessing it’s more than a few years and mileage most likely unknown
17-05-20, 08:16 PM | #3 | |
Sent from my SM-G973U using Tapatalk |
17-05-20, 08:34 PM | #4 | |
17-05-20, 08:35 PM | #5 |
17-05-20, 09:31 PM | #6 |
I'd be inclined to suggest Silkolene Maintain RSF 10W oil. It is nearer to most 15W oils and has a high viscosity index (VI) which means the viscosity doesn't change as much with temperature. You can see how it compares in the table at http://peterverdone.com/wiki/?title=Suspension_Fluid (it is now called "maintain" but used to be called PRO RSF, as in the table).
I use RSF 7.5W but I'm a bit lighter and prefer to be on the comfier side regarding damping. It's not the end of the world if you decide you need/want higher viscosity at a later stage. I get it from https://www.sportsbikeshop.co.uk/
17-05-20, 09:32 PM | #7 | |
18-05-20, 06:00 PM | #8 |
I'd also say 15W. Embee is right, as simply the W number isn't the whole story, but yep a bit thicker is good, the standard fork damping is a bit soft.
18-05-20, 06:04 PM | #9 |
18-05-20, 07:03 PM | #10 |
I mixed 10 and 15 just to thicken it a bit.
Options? | Jerussel | SV Talk, Tuning & Tweaking | 0 | 20-09-15 08:46 AM |
Replacing fork seals and fork set up? | Ricky650 | SV Talk, Tuning & Tweaking | 11 | 26-03-12 02:20 PM |
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) | monkey | Bikes - Talk & Issues | 8 | 28-10-07 11:59 PM |
K4 fork spares, damper tubes,preload adjusters,fork lowers | ianofbhills | For Sale - SV's and SV related items | 11 | 13-03-06 06:58 PM |
Front Fork Options | snoopy | SV Talk, Tuning & Tweaking | 15 | 21-01-05 03:16 PM |
