Old 19-08-13, 10:29 AM   #21
jambo
jambo's Avatar
Default Re: Tyre pressures SV650S?
Originally Posted by nikon70 View Post
No idea what mine is currently, will check tonight on way home and inflate and will feedback later. Never really filled up my tyres before, they usually get a puncture or wear out before then
This is probably making a bigger difference than the particular pressure recommended by Suzuki or Bridgestone
Jambo
Old 19-08-13, 07:42 PM   #22
Red Herring
Red Herring's Avatar
I think it very much depends on how you ride and how you like it to feel. Clearly the manufactures will give some "safe" guidelines but these will be compromises for a lot of us as not all of us are "standard" riders. I for instance weight in about 95kg in my gear and I use 30 front and 32 rear. It won't start to get dangerous for you until you start to go below 25ish or over 40 so my advice is to play around with them a bit and see if firstly you can tell the difference, and secondly which way you prefer it.
Old 20-08-13, 06:51 AM   #23
MJC-DEV
MJC-DEV's Avatar
For information I run my Avon Storm Ultra 2 at 33/36 and they work just fine for me at that pressure. No change of feel for +-1psi either.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 21-08-13, 01:18 PM   #24
nikon70
Ok just been out to check.
Was below 32 so am guessing maybe 30
It's now on 36...
Upon inspection of the rear end look what I noticed
Borked the tail tidy and the bloody plate!!! Am sure it's taken some tread off he rear tyre too!!!! Argh!! Although saying that it was low anyway. Didn't get many miles outta that rear, 6k BT 45s I think ...
Old 21-08-13, 01:22 PM   #25
Er that's nowt to do with your tyre pressures
Old 21-08-13, 01:31 PM   #26
nikon70
I know the plastic screw that holds it on vibrated the nut off and meant the plate was rubbing on the tyre and caused the tail tidy bracket to snap!! argh
Old 21-08-13, 01:34 PM   #27
nikon70
oh so if anyone has a hamicad tail tidy or something similar - i'm looking to buy...
also i need a number plate asap - anyone?
Old 21-08-13, 01:37 PM   #28
Local motor factors. You need to take V5 and ID these days
Old 21-08-13, 01:40 PM   #29
nikon70
yeah i know about v5.... will chance it... in watford town center anyone? do lloyds motorcycles do it?
Old 21-08-13, 02:05 PM   #30
nikon70
or a fender eliminator / undertray thingy
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Tyre pressures mxm35948 SV Talk, Tuning & Tweaking 13 10-09-07 04:18 PM
Tyre pressures for an SV650S K3. keithlackie SV Talk, Tuning & Tweaking 2 28-05-07 09:09 AM
tyre pressures ? DAX SV Talk, Tuning & Tweaking 20 12-12-06 09:28 PM
Tyre Pressures fizzwheel Tyres 21 26-03-05 09:04 PM
