Old 20-03-17, 11:36 AM   #1
tom_e
Default Rear brake res to MC hose size
Does anyone know the ID of the hose that runs between the rear res and the MC? Need some new stuff and the OEM parts seem to be special order everywhere and pricy.
tom_e is offline   Reply With Quote
Old 20-03-17, 11:46 AM   #2
SheepShagger
Default Re: Rear brake res to MC hose size
8mm
Sent from my SM-G935F using Tapatalk
SheepShagger is offline   Reply With Quote
Old 20-03-17, 11:48 AM   #3
SheepShagger
I used this stuff to do the rear on my build.
http://www.ebay.co.uk/itm/121518690884
Old 20-03-17, 11:50 AM   #4
tom_e
Cheers is it the same for curvy and pointy? Mine is a K5 if that makes any difference.
Old 20-03-17, 11:53 AM   #5
SheepShagger
The OE pipes are probably different to each other but that stuff i linked is quite flexible so should suit either, make sure you get a long enough length though.
99 sv650 rear brake hose spring clip size? Geodude SV Talk, Tuning & Tweaking 6 23-02-16 10:49 PM
Rear brake hose Winder SV Talk, Tuning & Tweaking 2 31-08-11 10:20 PM
Rear Brake hose svdemon SV Talk, Tuning & Tweaking 8 19-08-08 10:37 PM
Rear brake hose husky03 SV Talk, Tuning & Tweaking 9 09-11-07 08:28 PM
Front brake hose splitter securing bolt size? Tim in Belgium SV Talk, Tuning & Tweaking 5 12-06-07 07:53 PM
