Old 12-01-09, 11:12 AM   #1
Stu
Trinity
Stu's Avatar
Default Shoei Pinlock - still fogs up
My Shoei pinlock still fogs up
XR1000 bought in the summer came with the pinlock. I know the pins are ofset & I have gradually tightened them both up until the are now at they're tightest setting. There is no obvious gap but it still fogs up unless I am at motorway speed with the chin vent open or in town I have to crack open the visor.
I know it has been extra cold - but that is when you least want to open the visor, but even today wasn'y that cold, & on it''s tightest setting it still fogged up.
Old 12-01-09, 11:18 AM   #2
arcdef
Default Re: Shoei Pinlock - still fogs up
mine was doing this and i noticed when i put my tinted one in (you can see the seal better) that parts were either very thin or not even sealed, i mentioned it to the place i got it from and he said just to take it in, he would look at it and replace/sort it out.
also in order to find out where its not sealed take the visor off and breath on small areas at a time, may help may not!!
may be worth a try?
Old 12-01-09, 11:43 AM   #3
BBadger
Not to sure about the shoei but bar of soap or fairy liquid solved the fogging issue with my agv.
Not sure if its much help but a quick fix none the less.
Old 12-01-09, 11:44 AM   #4
sauluk
sauluk's Avatar
Mine fogs up in the mouth area, the condensation is too much because of the cold I think. Bit annoying too because when it fogs up it's more of an effort to check the speedo on the SV!
Now: 12 Multistrada 1200
Was: 09 R1200GS
Was: 08 CBR600RR
Was: Blue SK5
Was: KMX125.. stolen..
sauluk is offline   Reply With Quote
Old 12-01-09, 11:50 AM   #5
Mr Speirs
Mr Speirs's Avatar
Honest Officer
Old 12-01-09, 12:38 PM   #6
Perhaps a very thin layer of silicon grease around the seal?
Old 13-01-09, 10:08 AM   #7
sparkymarky
Never had any problems with fogging on my pinlock/Shoei Raid II. Can only assume that the insert is faulty??
Old 13-01-09, 12:50 PM   #8
Beenz
I'm on my third xr1000 now, no problems at all with the pinlock fogging. Just has to be a good fit.
Old 13-01-09, 06:15 PM   #9
Dangerous Dave
Stu, is it fogging up inside (the side against the visor) or the outside of the Pinlock?
Old 13-01-09, 07:13 PM   #10
Stu
Trinity
Stu's Avatar
i think both,
I have seen it inside the double glazing, but sometimes it's just on the outside of the pinlock (inside the helmet)
Pinlock Insert & Pins COLZO Helmets 4 18-12-08 01:22 AM
Shoei Pinlock Dark tinted insert Stu Stuff Wanted 10 07-05-08 10:15 AM
Shoei pinlock help jonny bee Helmets 5 10-02-08 12:10 PM
tinted pinlock? hovis Bikes - Talk & Issues 4 16-09-07 08:40 PM
Shoei Pinlock Visor problem! The Polarbear Bikes - Talk & Issues 5 19-04-05 08:03 PM
