Old 06-10-20, 09:46 AM   #1
Adam Ef
Adam Ef's Avatar
Default GSXR front end conversion guides?
As title.. does anyone kow of any good online info for GSXR front end conversions for the SV?
Or have experience of doing it and know of compatibilites and what to look out for? Thinking of a possible project, possibly with a naked pointy 2007 onwards. All just ideas at the moment though. Be good to get a realistic idea of what's involved and what to budget.
Past:
Old 06-10-20, 11:28 AM   #2
Red Herring
Red Herring's Avatar
Default Re: GSXR front end conversion guides?
It depends which SV you are converting but the K4/K5 GSXR600 front end goes straight into a pointy as I've done it. Have a search on here, been a few years but if I remember correctly some dedicated member put together a complete flow chart showing what wheel goes with which forks and brakes onto which frame......
Old 06-10-20, 11:37 AM   #3
wsmc549
There is literally a complete guide on how to do this right here in this forum. 2 of them actually. 11+ 600/750 is plug and play minus steering lock. 04/05 600 750 is 100% STRAIGHT SWAP.. Most complete front ends will go right on. Once you start mixing parts it gets complicated so consult the fork swap guides.
wsmc549 is offline   Reply With Quote
Old 06-10-20, 12:49 PM   #4
Adam Ef
Adam Ef's Avatar
Cheers. Searching shows up a lot of dead ends but found a couple of good threads including...
https://forums.sv650.org/showthread.php?t=101256
Past:
Old 06-10-20, 02:16 PM   #5
thedrewski86
Junior Member
thedrewski86's Avatar
svrider.com covers gsxr front end swaps ad nauseum, I would look there. It seems like every new rider who finds an old SV here in the States thinks they can't ride it until they put gsxr parts on the front so the forum postings are everywhere.
thedrewski86 is offline   Reply With Quote
Old 06-10-20, 05:50 PM   #6
CheGuevara
I installed a K7 GSXR750 front end on my K5 SV. From memory it went straight in (bearing swap perhaps, though I probably would have swapped them anyhow, so I don't actually recall if it was necessary). I believe I used a K5 GSXR 1000 top yoke.
There's bunch of old posts by me on here if it's any help/relevant, though I'm not sure I put all the info in any one spot.
Re the top yoke:
"I managed to get the SV lock to fit the K5 1000 top yoke (and clear the headstock) by filing the holes in the lock backwards and also I think splayed slightly outwards (they were slightly closer together I think than the GSXR mount). That gave me enough space to clear the headstock and the steering lock worked (with steering dead ahead). "
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 06-10-20, 06:02 PM   #7
Some useful links from my bookmarks
http://forums.sv650.org/showthread.p...ght=gsxr+front
http://forums.sv650.org/showthread.php?t=103351
https://uk.farnell.com/honeywell/1gt...oth/dp/1225630
https://www.leevalley.com/en-ca/shop...-earth-magnets
https://www.leevalley.com/en-ca/shop...rcular-magnets
Old 07-10-20, 05:55 AM   #8
Adam Ef
Adam Ef's Avatar
Very helpful list. Thanks Darren.
Past:
Old 07-10-20, 09:48 AM   #9
Dave20046
Dave20046's Avatar
I did an SRAD front end so can't really help you, but it was a 3 hour job. Sourcing the parts was the biggest pain in the ****.
If you go K5 you can just buy a complete k5 end or bits all from the same bike.
You might want a word with your insurer/time it to be done at renewal time so they haven't got you over a barrel.
Old 07-10-20, 05:57 PM   #10
Adam Ef
Adam Ef's Avatar
It wold be on a bike that I don't own yet. All hypothetical at this stage.
Past:
2004 GSXR 600/750 Front End Conversion Muel For Sale - SV's and SV related items 13 10-02-18 08:21 PM
GSXR Front end conversion -SOLD Vergey For Sale - Other Bikes and General biking items 17 14-08-11 11:47 AM
GSXR front end conversion using SV front wheel maviczap SV Talk, Tuning & Tweaking 24 13-03-10 02:06 PM
SV GSXR front end conversion tiernanobrien SV Talk, Tuning & Tweaking 16 19-07-09 02:29 PM
