30-06-09, 10:50 PM | #1 |
Starter button temperamental
My starter button is playing up. Recently it's been taking a couple of tries, today it's quite a few.
I go throgh the normal procedure - bike in neutral, switch on, choke on, pull in clutch and press button then nothing. I have to press the button quite a few times before it wakes up and starts the bike. Once the button works it starts fine and all is normal. Usually the first one may not work but if I press it again it's fine. Tonight I must have pressed it ten times before it started! It runs fine once it's started, it's just getting it started does anyone have any ideas? |
30-06-09, 11:07 PM | #2 |
Re: Starter button temperamental
might be a bit of crap in there, just take it apart and clean.
could also be the clutch switch though, clean that while your at it |
30-06-09, 11:23 PM | #3 |
Thanks hovis
I've misplaced my haynes manual so have no idea how to do the clutch switch, is it easy? I'm assuming that taking apart the starter switch is a lot easier? |
01-07-09, 06:53 AM | #4 |
they are both pretty easy really. The clutch switch is really basic, it has a slider and some contacts. Located just under the clutch lever on the lever mount, one screw removes it. Give it a good spray with electrical contact cleaner and it should be right.
The switch gear isnt that difficult to remove although on the naked its combined with the throttle mechanism and be a little more tricky. Same thing, pop it open and clean with contact cleaner. |
01-07-09, 07:32 AM | #5 |
Thry this to eliminiate the clutch switch.
Look under the clutch lever, you will see a plug, Pull this off and get a paper clip. Make a connection between the two slots with the paper clip and tape up with some insulating tape. If the bike starts on the button everytime, then its the clutch switch. Leave the bodge in place and forget about it, or clean the switch out or buy a new one. |
01-07-09, 08:31 AM | #6 |
Thanks for your help. had to take the tube in today because the button had packed it in and i was worried that if i got to work getting home again would be even worse.
i'll try fiddling when i get home. Viney, that clutch switch trick looks nifty, thanks a lot, hopefully its that! |
01-07-09, 09:00 AM | #7 |
Sounds like clutch switch as the others say, I had the same problem, to such an extent that once or twice I used to revert to bump starting the bike.
01-07-09, 09:32 AM | #8 | |
01-07-09, 06:20 PM | #9 |
Guys, thank you so much for your help, paperclip worked perfectly! Bike starts first time every time! The tube was horrible today, back on the bike tomorrow
01-07-09, 06:32 PM | #10 |
Just make sure if you are going to break down, try and do it near a 'Staples' store.
or you could of course just replace the clutch switch. I permanently wired mine together and removed the switch, same with the sidestand switch. |
BBC red button coverage | SAMMY650 | Idle Banter | 1 | 14-06-09 02:47 PM |
ignition button does nothing | budrosmith | SV Talk, Tuning & Tweaking | 28 | 31-01-07 03:03 PM |
SV650 Starter Button? | Torn-Thorax | SV Talk, Tuning & Tweaking | 3 | 09-09-06 02:49 PM |
