Old 14-05-19, 08:58 PM   #1
simon1
Default Sv carby cuts out
Hi
I have an sv carby...starts and ticks over fine....but when I rev it it instantly cuts out....then takes 5 mins to start.....thought it might be electrical because of the the way it instantly stops.....but then with it taking a little while to start while turning over,seems like it might be fuel starvation?...…..although the way it stops is so instant that I thought it would splutter a little bit before stopping if fuel starvation?....what are peoples thoughts?
simon1 is offline   Reply With Quote
Old 14-05-19, 09:35 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Sv carby cuts out
Has it been sitting unused for a little while?
2001 SV650 in shimmerin green, Not broken anymore
Old 15-05-19, 10:02 AM   #3
R1ffR4ff
R1ffR4ff's Avatar
Originally Posted by simon1 View Post
Hi
Quick test.Try with the filler cap open.Sometimes a blocked cap can cause fuel starvation by causing a partial vacuum.
Old 15-05-19, 10:42 AM   #4
simon1
Hi
Bike has not been standing...……..will try the open cap and see...
Old 15-05-19, 12:05 PM   #5
simon1
Thumbs up Re: Sv carby cuts out
Update!!…..So,the problem was,the foam that's glued under the tank was slightly lose....when reving the engine,the air filter would suck it down,enough to cover the air box hole and flood it!!!!...check your foam guys!!...thanks very much for your replys and help..
Old 15-05-19, 12:06 PM   #6
R1ffR4ff
R1ffR4ff's Avatar
Nice one
Glad it was a simple fix.I've had similar little gremlins over the years
Old 15-05-19, 12:10 PM   #7
simon1
Yes glad I found it...I was going to start stripping down the loom and taking the carbs off etc!!!......
K1 starts but cuts out after a second or two. ejohnh SV Talk, Tuning & Tweaking 32 14-06-18 06:02 AM
Engine cuts out. Bike_Nutter Bikes - Talk & Issues 2 18-09-14 05:26 PM
Police Cuts Bluefish Idle Banter 86 16-07-11 10:58 AM
Power Cuts! BomBalong SELKENT 2 22-07-09 06:46 PM
Salary cuts keithd Idle Banter 23 18-03-09 03:58 PM
