Old 02-12-19, 12:19 PM   #7771
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Gripe of the day - What is yours?
Originally Posted by admin View Post
Sent from my Moto G (5) using Tapatalk
I've got a 2015 Moto G3 X1541 running Android Pie<grin> Lineage 16 and testing Android Q/Android 10 Lineage 17
Old 02-12-19, 01:26 PM   #7772
admin
John T
admin's Avatar
Default Sig line. I had a G1 until last Xmas. They seem to last well and are good value.
Old 02-12-19, 10:06 PM   #7773
SV650rules
Denso and NGK plugs that seem too cheap probably Chinese knock-offs, NGK even issued articles with pictures telling people what to look for on fake plugs. You can get reasonably priced plugs from reputable sources...
2016 SV650 AL7
Old 03-12-19, 07:32 AM   #7774
Adam Ef
Adam Ef's Avatar
Originally Posted by SV650rules View Post
...You can get reasonably priced plugs from reputable sources...
Considering the Iridiums last about 30,000 miles I'm quite happy to pay proper price for them to work without worry for a few years.
Past:
Old 03-12-19, 07:36 AM   #7775
Adam Ef
Adam Ef's Avatar
In other news... I went to try and do the starter valve sync again last night just to check it in a last ditch attempt before throwing money at the problem and found what looked like a loose air inlet pipe. Fairly sure I put them all back on ok when I reassembled it (it worked fine for a few days after) but maybe it wasn't quite on and came off while riding the other day. Test ride this morning when the temperature gets above zero. Hopefully I'll start posting in the smile thread again soon instead.
Past:
Old 03-12-19, 08:58 AM   #7776
admin
John T
admin's Avatar
Fingers crossed for you.
Sent from my Nexus 7 using Tapatalk
Old 03-12-19, 09:59 AM   #7777
R1ffR4ff
R1ffR4ff's Avatar
Just as an aside. I wonder if the Plug sticks are just a design choice.I'd like to know how they are constructed as I suspect Racing NGK Straights might work in place of them and are much cheaper than OEM :/
Old 03-12-19, 10:12 AM   #7778
Adam Ef
Adam Ef's Avatar
They're Denso sticks. So there may be other possibilities. Good suggestion. I'll do some research as they will all go at some point.
I've got a Denso being delivered today from a breakers. But the bike has started this morning (rough, but it s very cold out).. so I'm off out to run a tank of fuel through to see how the economy is ..
Past:
Old 03-12-19, 10:15 AM   #7779
SV650rules
https://www.opieoils.co.uk/c-381-den...le-spark-plugs
Honda VFR800 782cc injection 2002-->
I have bought lots of spark plugs and filters ( and oil LOL ) from Opie Oils and they have all been fine...
DENSO Iridium Tough Spark Plug [VNH27Z] 5631
RRP £17.64
£12.95
2016 SV650 AL7
Old 03-12-19, 10:17 AM   #7780
R1ffR4ff
R1ffR4ff's Avatar
The reason I ask Adam is that I've been around a while going through Ignition system changes over the years from the old Coil and Distributor systems then CDI and of course now EFI.
I suspect that the Spark plug Caps are still the same basic in-line Resistor types brought in when CDI units came into being to suppress,"Back EMF" which affected some Ignition circuits.
It would be good to know for future cheaper alternatives
whats ur biggest gripe about the uk? kwak zzr Idle Banter 101 15-11-16 06:33 PM
heated grips gripe adw Bikes - Talk & Issues 8 12-05-10 02:48 PM
