Old 01-05-19, 08:20 PM   #1571
Othen
Default Re: What have you tinkered with today?
Originally Posted by SV650rules View Post
Lets face it a lot of crimps are done with wrong size lugs and a pair of pliers or side cutters because correct tools not available, decent crimp tools are pricey bits of kit.
Both statements are true: the majority of DIY crimps I’ve seen on bikes and cars have been done with pliers and are often useless (very prone to vibration, often creating intermittent problems that are hard to find). Also a proper crimping tool is slightly expensive (and a specialised tool that can’t be used for anything else), but I have found them to be invaluable. A proper crimped joint is pretty good.
Sent from my iPad using Tapatalk
Old 06-05-19, 06:11 PM   #1572
Chris_SVS
Chris_SVS's Avatar
Cruise control fitted and tested Super Tenere switchgear to arrive later this week so the controls will be factory OEM looking instead of this
Chris_SVS is offline   Reply With Quote
Old 07-05-19, 12:29 PM   #1573
Craig380
Does the cruise control only work on bikes with a fly-by-wire throttle? I know how it works in cars etc, I'm curious about how all the features like clutch / brake usage disengaging cruise works on a bike ....
Old 07-05-19, 12:45 PM   #1574
Scittyf
Surely just the same. I mean most levers already have switches that are used for lights. So surely its a case of tapping into those?
I'd imagine its easier to implement on bikes with fuel injection and throttle bodies that are electronically controlled. Rather than carb's with mechanical parts.
Scittyf is offline   Reply With Quote
Old 07-05-19, 12:50 PM   #1575
R1ffR4ff
R1ffR4ff's Avatar
I have a simple but super effective Cruise Control on my 99,
https://www.ebay.co.uk/itm/Vista-Cru...frcectupt=true
There was a UK supplier but I can't find them now
Cost about £25 which seems a lot but it works fantastic so worth it IMHO.
I fitted fatter grips to my SV so sanded off the silly Suzuki fins on the throttle sleeve which also allowed me to fit the,"Vista".
Old 07-05-19, 01:31 PM   #1576
Chris_SVS
Chris_SVS's Avatar
They have different kits for various applications, can't say I know much about those.
Works much the same on this system, clutch or either brake will kill the cruise. Bu since it piggybacks a tach signal, I have wired that part to also piggyback my quickshifter, which will also cut the cruise.
Old 07-05-19, 02:04 PM   #1577
Othen
Default What have you tinkered with today?
I saw Chris-SVS’s article about fitting cruise control to a SV above and was inspired to try something similar - so today I’ve fitted air conditioning and an information module from a Saab 900. As you can see from the photo, it is quite a neat fit inside the SV’s fairing, and even though I say so myself it enhances the bikes looks and functionality:
I just have to tidy up the switches a bit, find somewhere to fit the compressor (I was thinking of running it from the back tyre, just like with a pushbike dynamo) and sort out the wiring:
As you can see, I’ve ended up with a couple of loose wires - I’m not sure where they go and can’t find anything on the SV or Saab’s wiring diagrams to help, does anyone have any ideas?
I was going to fit some heated grips this week, but as you may see I have a heater now, so I can save £50 on those
Old 07-05-19, 02:20 PM   #1578
Chris_SVS
Chris_SVS's Avatar
Needs to go through the grubnuts towards the donkey flange
Old 07-05-19, 02:22 PM   #1579
Othen
Ahhhh! My Saab wiring diagram is in Swedish, I tried Google translate but that gave me a recipe for reindeer meatballs.
Old 07-05-19, 02:42 PM   #1580
Chris_SVS
Chris_SVS's Avatar
Tasty I love Venison when it's well priced
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
