Old 30-09-18, 02:39 PM   #11
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Idle Screw Not Working?
It will do no harm running half a bottle of fuel cleaner into the fuel tank next fill-up.Then a couple of caps full when you feel like it.Ethanol in the modern fuels seems to gum-up fuel lines and carbs in some cases and this helps keep them all clear.
I normally use Redex but also the cheap Twin pack Carlube stuff from ASDA does a decent job as well.It also stops the fuel going stale.
Also balancing your Carbs is not a hard job on the SV but here's your self XMAS present suggestion and what I've used for well over 10 years,
http://www.carbtune.co.uk
Absolute doddle to use and comes with everything you need.So well made it will most likely last a life-time,well at least mine<grin>
Old 04-10-18, 04:15 PM   #12
slaked
If anyone's interested Robinson's have the original new Suzuki plug cap in stock on sale for £8.20 (plus a couple of quid for the seals) instead of the usual £30. Mine just arrived today, seems a bit of a bargain!
https://www.robinsonsfoundry.co.uk/s...650xelectrical
Old 04-10-18, 07:28 PM   #13
R1ffR4ff
R1ffR4ff's Avatar
Good price but check the Resistance.They should be 5k ohms
Where's the idle screw granty92 SV Talk, Tuning & Tweaking 7 21-07-12 07:15 PM
Fast idle not working SVMAT SV Talk, Tuning & Tweaking 2 06-05-10 05:23 PM
Idle Adjuster Screw mattglavin SV Talk, Tuning & Tweaking 11 11-10-07 12:37 PM
Idle adjust screw? jec444 SV Talk, Tuning & Tweaking 6 01-07-06 02:53 PM
Bloody idle screw! Mervin SV Talk, Tuning & Tweaking 16 04-02-05 08:00 AM
