Old 28-09-18, 12:58 PM   #1
ManOfKent
Junior Member
Default Curvy Carbs - Choke plunger O ring size.
All,
Once I recovered from the shock of paying for two genuine Suzuki Ochoke plunger O rings (£5.50 each before VAT!), I whipped out my electronic calipers and measured them up at :
OD = 12.5 mm
ID = 9.5
Thickness = 1.5
Given that Polymax sell Viton ones of this size at 0.38p before VAT does anyone know a reason why the Suzuki ones would be better?
(https://www.polymax.co.uk/o-rings/rubber-viton-oring/)
OS
ManOfKent is offline   Reply With Quote
Old 28-09-18, 03:07 PM   #2
Default Re: Curvy Carbs - Choke plunger O ring size.
suzuki ones are no better that others in the fact that if you buy the suzuki ones they are within spec. now the big problem with buying other ones is that they might not be fully round, exactly the correct size and made from inferior materials. however if you buy them from a reputable company and ask them to had sort (extra cost) you will get the perfect ones. this is also true of calliper and fork seals.
material can make a difference in critical components as to "crush" tolerance etc.etc but we are talking rocket science and medical equipment etc.etc.
as long as the oring forms a proper seal and is impervious to petrochemical then all is good.
marksman industrial and simply bearing are a good cheep source of bearings and seals.
Old 29-09-18, 02:04 PM   #3
R1ffR4ff
R1ffR4ff's Avatar
As Biblio says.So long as they seal go for it.I've used O-rings from cheap ebay kits on engines/carbs and even cooling pipes and so long as they fit they have never given a problem even with cheaper butyl/nitrile ones and Viton® are above their specs.
1 choke plunger mulholland Stuff Wanted 0 16-01-18 11:39 PM
Curvy Choke Plunger O rings going free. Dipper For Sale - SV's and SV related items 2 27-08-11 05:10 AM
Seized Choke Plunger Kiyonari Bikes - Talk & Issues 13 28-07-11 06:07 PM
Carb plunger o ring size? bigchris SV Talk, Tuning & Tweaking 12 07-07-11 12:43 AM
Stuck Choke Plunger 2000curvy SV Talk, Tuning & Tweaking 8 14-12-10 06:58 PM
