Old 29-09-18, 04:08 PM   #1
SV650rules
Default Vacuum oil extractor
https://www.amazon.co.uk/dp/B000WZF7...740111_TE_item
Just bought one of these for our cars and lawnmower ( have to turn mower upside down to get old oil out, can get messy). Question is has anyone used similar for getting fork oil out, and maybe even engine oil ( ducks )
2016 SV650 AL7
Old 29-09-18, 04:51 PM   #2
Default Re: Vacuum oil extractor
with fork oil you need to set a level and not the amount of oil so unless you know the exact amount that each fork leg takes then no you cant just suck it out, also you will never get all the oil out.
as for engine oil then whats the hassle in taking a sump plug off...
i can understand that gadget being used for lawnmowers as its indeed a PITA to change oil but for something with a sump plug.. ermm no.
could be useful for bleeding brakes...
its the same as people using a torque wrench for everything.. its not needed.
Old 30-09-18, 08:10 AM   #3
aesmith
I've used one for years, original bought specially for the boat where access to the sump is impractical. Now also used for quite a few other things.
I can get most of the fork oil out with the forks still fitted. Support front of bike, remove top caps, remove springs, lower bike so forks are fully compressed. I find it a lot easier with a length of rigid pipe on the end of the suction hose, so you can be sure you're poking it down as far as it can go. I say "most" because it won't get at any sludge lurking in the bottom.
Can be used to set the fork oil level as well by sucking out excess if you mark the correct level on the tube.
I didn't find it helpful with brakes, too much leakage around the threads of the bleed screw.
You can't use it for engine oil in the SV because you the clutch or something is in the way so the tube can't even get below oil level let alone right to the bottom of the sump.
Old 30-09-18, 09:04 AM   #4
SV650rules
I have used mityvac to bleed car and bike brakes, on one of the cars I used some small O rings compressed between hexagon and brake cylinder to stop air being sucked in around thread, figured out they would seal thread against crud from outside as well, but when I looked a year later when replacing pads a couple of the O rings had gone, don't know if brake fluid attacked them. Teflon tape around the thread near hexagon works well, I keep it away from sealing end of nipple as I know only too well that Teflon tape is great at extruding along threads as you tighten them.
On our cars I will change oil twice for every filter change. So oil twice a year, filter once.
2016 SV650 AL7
OMO - Can You Recommend A Decent Bolt Extractor? (And drill bits) Steve_God Bikes - Talk & Issues 13 25-05-15 08:50 AM
WTB: Vacuum port cap for k6 MetalJonesy For Sale - SV's and SV related items 1 19-08-12 10:14 PM
Caliper Piston Extractor Tool - only £3.99 no_akira For Sale - Other Bikes and General biking items 8 17-08-11 06:59 AM
What do you think of these vacuum gauges? barwel1992 Bikes - Talk & Issues 6 02-03-11 09:34 AM
Vacuum Hoses andyb SV Talk, Tuning & Tweaking 3 09-04-08 07:11 AM
