Old 21-06-06, 04:07 PM   #1
mudge32
Default Anyone, or knows anyone who, owned a Triumph GT6?
A work-mate's looking at maybe buying one and I wondered if anyone had any insight into owning\doing up one of these beasties?
Piccie to jog folks memory
Old 21-06-06, 04:13 PM   #2
Marshall
i had a spitfire, which was the convertable smaller engined jobbie.
electrics and engines are pretty easy to work on
there a trimph place for parts in telford thats pretty good.
its the chassis youve got to be carful about, if its rotten, its a right mare to put right
Old 21-06-06, 04:19 PM   #3
mudge32
He keeps eying up this one http://cgi.ebay.co.uk/TRIUMPH-GT6-RE...QQcmdZViewItem
For restore I hasten to add
Old 21-06-06, 04:29 PM   #4
Marshall
im not entireley sure why the two carbs are sticking out through the bonnet??
but id definatley advise going and having a look at it.
i know theres a place around called the spitfire graveyard, and theres a forum about aswell, cant remeber the url to that one though
http://www.spitfireg1.f9.co.uk/frame.htm
http://www.triumphspitfire.nl/graveyard.html
HTH
Marshall
Old 21-06-06, 04:42 PM   #5
mudge32
We wondered that but here's a Spitfire with a strange growth as well (Mind you this one's been converted!!)
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ayphotohosting
Old 21-06-06, 04:58 PM   #6
kjames
i used to have a spitfire aswell.. had it for about 7 yrs, and probably replaced most bits at some point or another.
the strange growth on the yellow one, is because its got the 6 cyl engine out of a gt6 in it.. (or at least the bonnet off a gt6)
a spitfire had 4 cyylinder, and the extra 2 clash with the bonnet.. hence the bulge.
not sure why you would need to cut holes for the carbs.. either the engine has been mounted too high (or the carbs) are the wrong ones.
theres a big hole in the bulkhead on the pic... which is an expensive area to fix. can you mate weld??
bonnets rot around the front, behind the headlight.. chassis rails at the front, behind the bumper.. (any pretty much everywhere).
unless he's doing it as a hobby, its far cheaper buying one thats in good nick and just tinkering with it, rather than a basket case, that needs heaps of cash.... the yellow one would be a far better buy if he can raise the cash... and a bit nippy
k (a bitter ex spitfire owner)
Old 21-06-06, 05:28 PM   #7
the_runt69
The carbs are through the bonnet because the GT6 had a 2 litre engine not the 2.5 that is in that one. The 2.5 was in the TR6 but with Petrol injection not twin carbs.
H
Old 22-06-06, 09:59 PM   #8
Balky001
Balky001's Avatar
My brother had a GT6 - or poor man's E-Type as they were known. Contrary to most classics where people believe original are best - the Mark I and II has really bad suspension and brakes. The suspension was better in the Mark III. If the rear lights are small roundish jobbies its probably a I or II, the III had wider cluster. Nice cars once sorted.
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 23-06-06, 08:04 AM   #9
Reckless Rat
I had a MkIV 1300 Spitfire, with a Sebring fastback hard top... so looked like a GT6, but had the lower insurance of the 1300, and roof off bonus in the summer. Sounded good too with a Peco big bore straight thru exhaust, but performance was still feeble
I'd say it's an ideal project, but it's keeping the rot at bay that's the problem though all the mechanicals are straight forward, I'd guess some parts are getting scarce... but then there must be more specialists making parts than when I had mine.
I've got a feeling that the GT6 gearbox and back the transmission's a bit fragile as I think it's all as per the lower spec/lower power Spitfire.
RR
Old 23-06-06, 09:47 AM   #10
Biker Biggles
Biker Biggles's Avatar
I had a few Triumph cars and they make good pets,with parts readily available and reasonably priced.Like all old cars rust is the big enemy,but the GT6 is a seperate chassis design,so nothing is unsolvable.You will need a toolkit,and somewhere to keep the car and work on it.The street is a poor option.
Anyone own/owned a TL1000R? Dappa D Bikes - Talk & Issues 85 11-12-08 06:18 PM
Anyone here previously owned.... Nostrils SV Talk, Tuning & Tweaking 0 16-04-07 07:38 PM
Bikes you've owned..... 1world2wheels Bikes - Talk & Issues 43 19-06-06 02:54 PM
Anyone owned a ZX7R? TheMickster Bikes - Talk & Issues 13 15-06-06 02:21 PM
anyone on here owned a TL1000R? weegaz22 SV Talk, Tuning & Tweaking 25 27-04-05 10:52 PM
