Old 25-01-21, 12:42 PM   #11
vugar
Junior Member
Default Re: Corrosion on engine exhaust mounts
Thanks for the pics and the info there. Definitely not touching my studs then. Great job on the ones you've done though!
My main issue again is the part of the engine that the stud goes into, it's heavily corroded and slowly falling apart. I've highlighted it using the picture you sent as it's more clear than mine
vugar is offline   Reply With Quote
Old 25-01-21, 01:14 PM   #12
dozi
Junior Member
get a wire brush on the engine casing where the stud is held, it will tell you the true extent of any corrosion. where abouts in the UK are you ?
dozi is offline   Reply With Quote
Old 25-01-21, 07:27 PM   #13
SV650rules
I sprayed my pipes black ( high temperature matt black paint ) on my AL7, never been too fussed about 'shiny pipes' - the black pipes actually blend into the bike quite well.
If you don't need to remove exhaust and it isn't blowing I would follow previous good advice and leave well alone.
2016 SV650 AL7
Old 04-02-21, 10:56 AM   #14
Wire brush the loose stuff off and leave well alone unless you really need it off. gob everything in ACF50.
Biggest reason for needing to take pipes off is to remove swingarm to do bearings.
They fuse into the head. Nuts are a nightmare... Nibble the nuts off with a grinder and tap them round with a punch to save snapping the studs.
Exhaust will be seized into the head from galvanic corrosion between the steel and ally. Get a piece of wood against the exhaust and give it a good clout one way then the other to wobble it free.
Begging a favour - peg spanners for engine mounts. Nelson SV Talk, Tuning & Tweaking 8 20-01-11 04:03 AM
Pitting On Forks & Exhaust Corrosion stephen365 SV Talk, Tuning & Tweaking 10 10-08-08 08:47 PM
front cylinder engine mounts kwak zzr SV Talk, Tuning & Tweaking 4 01-03-07 08:53 PM
Corrosion on Engine Casing I'm_a_Newbie SV Talk, Tuning & Tweaking 2 31-01-07 12:15 PM
Exhaust bolt corrosion mynameis SV Talk, Tuning & Tweaking 2 06-12-04 11:03 PM
