Old 18-02-21, 08:14 PM   #1
trickydickym
Junior Member
Default sv650 2018 indicator problem
Bought this bike with a tail tidy which I didn't like, so I've gone back to the original rear end which came without indicators. I couldn't track down any oe indicators so bought a couple of late bandit units. Now they work but flash too fast. Anyone had a similar problem?
trickydickym is offline   Reply With Quote
Old 18-02-21, 10:31 PM   #2
Adam Ef
Adam Ef's Avatar
Default Re: sv650 2018 indicator problem
Hyperflash. You need different relays for them. Sometimes you can by inline resistors.
Past:
Old 19-02-21, 09:54 AM   #3
Seeker
Seeker's Avatar
Are the front indicators standard - or has someone fitted LED bulbs? Similarly, the Bandit rear indicators - incandescent or LED bulbs? The stock 2018 SV indicator relay doesn't support LED bulbs (but you can get one that will). You should have 21W incandescent bulbs front and rear (on each side) as standard.
2016 SV650AL7
2023 GSX-8S
Old 20-02-21, 11:16 AM   #4
R1ffR4ff
R1ffR4ff's Avatar
There's a couple of options to get them running correctly,
https://ldmotorcycles.co.uk/blogs/ne...cle-indicators
HTH
Old 21-02-21, 06:22 PM   #5
trickydickym
Junior Member
Thanks for your message. I think I've identified the problem the front bulbs are 21w but the new indicators I have put on the rear have 10w bulbs
Old 21-02-21, 06:23 PM   #6
trickydickym
Junior Member
Thanks
indicator problem please help. Ryan Butland Bikes - Talk & Issues 23 19-05-15 06:55 PM
SV650 03 Indicator problem gibsdsid SV Talk, Tuning & Tweaking 8 08-07-12 10:57 AM
Indicator problem. gabrielkeown SV Talk, Tuning & Tweaking 8 29-07-10 08:54 PM
Indicator problem blackrat SV Talk, Tuning & Tweaking 6 08-09-08 05:28 PM
Indicator Problem Side MS SV Talk, Tuning & Tweaking 23 26-05-08 07:11 PM
