20-02-21, 04:22 PM | #1 |
c40 error code
Would have been my smile of the day, but just a short distance into my ride I spotted the FI light on. Dealer mode suggests "-c40" but I'm struggling to find this code anywhere
Ran fine last about 5 or 6 weeks ago. Seemed to run fine today - nothing seemed out of sort apart from the warning.
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
20-02-21, 04:31 PM | #2 |
John T
Re: c40 error code
20-02-21, 04:56 PM | #3 |
Re: c40 error code
Thank you!
20-02-21, 05:14 PM | #4 |
Re: c40 error code
Follow up question- where is the idle adjustment screw on the fully faired k9? Do I need to remove the bodywork?
20-02-21, 05:23 PM | #5 |
John T
Re: c40 error code
I'm trying to remember where it was on my k04, probably in the same place. I'll have a think.
20-02-21, 05:35 PM | #6 |
John T
Re: c40 error code
It should be visible on the left side poking out of the trellis frame. Saying that I've read that it might have disappeared on later models and managed by the ecu. I've also read that it was just the extension cable that's been removed and you can adjust the stop screw directly on the left hand of the front throttle body where the throttle cable connects.
20-02-21, 05:38 PM | #7 | |
Re: c40 error code
if your having problems with the bike cutting out whilst coming to a stop then its either the clutch switch or the sidestand switch.... if it is dont bypass then or it screws with the idle. |
20-02-21, 05:45 PM | #8 |
Re: c40 error code
No noticeable problems apart from the FI warning. The idle when warm is very slightly above 1000rpm, so presumably a bit low.
20-02-21, 06:41 PM | #9 |
Re: c40 error code
have you lifted the tank recently? sometimes the vacuum pipes get kinked or the TB bungs for the vacuum spigot perish.
any twin spark SV bike will not have idle high or low when warm and only slightly high when cold. check the ISC connector for moisture. its a sealed unit so it can trap moisture. from the genuine suzuki SV K7 onwards manual supplement. |
05-03-21, 09:31 AM | #10 |
John T
Re: c40 error code
Bike magazine mentions the C40 code this month in relation with the GSXR750. It's a known problem with after market clutch levers not engaging with the clutch cutout switch properly. Do you have standard levers?
Admin for this forum and the main site. John@sv650.org Last edited by admin; 05-03-21 at 10:05 AM. |
error code c-42 | pencil shavings | SV Talk, Tuning & Tweaking | 66 | 24-05-21 01:57 PM |
C42 Error code - K8 | Lazadude | SV Talk, Tuning & Tweaking | 19 | 25-05-14 10:54 PM |
f 1 error code? | maz | Bikes - Talk & Issues | 9 | 19-02-12 11:33 AM |
error code c24 | schmector | Bikes - Talk & Issues | 3 | 24-05-11 01:16 AM |
FI error code c44? | Bibio | SV Talk, Tuning & Tweaking | 0 | 29-05-09 02:13 PM |
