Old 18-04-13, 06:37 AM   #1
big jc
Default Sv1000 lower fairing bracket
As per the title I've managed to get myself some lowers but they didn't come with the brackets, big al is sorting the paint out for me and Geordie mick sorted me out the lower brackets, now all I need are the main side supports, the "j" shaped ones that the standard crash bung would attach to.
Any help greatly appreciated
John.
Old 25-04-13, 08:26 PM   #2
big jc
Default Re: Sv1000 lower fairing bracket
Bump
Old 02-05-13, 09:20 PM   #3
sam-bliss
http://forums.sv650.org/showthread.php?t=198126
Not sure if the 650 and 1000 kits are the same though
Old 03-05-13, 05:59 AM   #4
big jc
From what I've seen so far the thou is slightly different but thanks anyway
John.
Old 03-05-13, 07:02 AM   #5
Nobbylad
Nobbylad's Avatar
I would strongly recommend using R&G crash bungs instead of the stock hangers. If you are unlucky enough to drop the bike, the stock ones will snap immediately and likely punch a hole through the fairing lower.
Old 03-05-13, 10:21 AM   #6
big jc
The r&g set up for the thou is different, they do not replace standard fairing mounts they sit to the rear of the fairing. The only set I have found anywhere that do replace the standard mounts are moto solders from the us, however they are double the price of r&g and will incur import tax! So roughly between £130 and £150?
SV1000 side support (lower fairing bracket) flymo Stuff Wanted 6 18-03-13 06:40 PM
Lower Fairing Bracket Curvy K2 Binky Stuff Wanted 1 11-07-11 05:57 PM
Lower Fairing Bracket SIII Stuff Wanted 14 01-06-11 08:27 PM
SV 650 2003+ Lower Fairing Bracket(s) Ward_650 Stuff Wanted 1 01-11-10 09:08 AM
lower fairing bracket copper kettle Stuff Wanted 0 16-01-06 11:47 AM
