Old 22-10-18, 11:36 AM   #1
glang
Default chain plastic slider
always wondered about the plastic slider that keeps the chain off the top of the swingarm. Mines showing quite a bit of wear now so I take they are replaceable but, typically, how many miles do they last?
Old 22-10-18, 11:40 AM   #2
Default Re: chain plastic slider
Depends on how you look after the chain and that section of the swing arm
Yes, replaceable. Cheaper than replacing the chain and swing arm, as its providing a vital job
Old 22-10-18, 12:29 PM   #3
shiftin_gear98
shiftin_gear98's Avatar
Having looked at mine yesterday. It's showing shallow grooves in it from the chain.
But at 54,000 miles I think it'll out live the rest of the bike.
Old 22-10-18, 12:59 PM   #4
glang
Thanks. I look after my chain reasonably well but the gouges in the slider are quite deep. Maybe its a case of initial rapid wear that produces the grooves and then the rate slows as the centre part of each link starts to make contact with the slider......
Old 22-10-18, 01:59 PM   #5
Craig380
I think that's probably it.
R&G slider - how much ? barwel1992 SV Talk, Tuning & Tweaking 13 25-11-10 03:25 PM
R&G Crash Bung (slider) barwel1992 Stuff Wanted 0 23-11-10 08:06 PM
Frame Slider Bolts rick0361 SV Talk, Tuning & Tweaking 0 26-03-08 10:26 PM
What plastic are the plastic bits made out of? Mark_h SV Talk, Tuning & Tweaking 3 24-03-08 08:32 PM
Plastic / Fairing Repair (Plastic Welding) Solution MattP SV Talk, Tuning & Tweaking 2 29-06-06 04:14 PM
