Old 26-09-24, 04:31 PM   #11381
rowdy
rowdy's Avatar
Default Re: Gripe of the day - What is yours?
Just got home from work. Met the contractors this morning before I left, and searched for a reason for the collapse.
When I moved into the property, the previous tenant erected a terribly built utility room on the side of the house, as has been done with every house in the street. I immediately tore it down and re built it.
However, the previous tenant took the downpipe from the house and diverted it into a blue water butt (the kind used on building sites to fill with water to knock up with) that was just left to fill up and overflow with nowhere for the rain water to go.
When I rebuilt the utility room, I dug down to the footings of the house and built up a kind of French drain, creating a channel with engineering bricks and concreting inside the channel with a fall to the waste drain about a meter along the house and filling it with shingle thus creating a run off and somewhere for the rain water to go. The outside tap is above this and after running it for a period it appears that over time this has now failed and allowed the water to disperse into the ground.
Now, what neither I or the contractor can quite understand is how and where tue sheer amount of soil, a mixture of sandy loam, clay and such has disappeared to.
There are working sand pits still, around a mile ir so from my home. The property was built 100 years ago originally for workers that were building the local railway line so whether there was some historic mining for materials I don’t know. Maybe there is a fissure under the ground somewhere below the property, but to put in perspective quite how much ground has disappeared, the contractor has ordered 17 bulk bags of shingle and type 1 mot! Which to me seems excessive for rain water run off from the narrow end of the house (pitched barn end, approx 4m length of gutter.
Old 27-09-24, 06:53 AM   #11382
redtrummy
Thanks Rowdy. Hope it's all successful. Could well be old mine workings involved somewhere along the line
redtrummy is offline   Reply With Quote
Old 29-09-24, 02:49 PM   #11383
Bloody hell Rowdy thats some serious hole. Hope its sorted soon.
Old 29-09-24, 02:50 PM   #11384
rowdy
rowdy's Avatar
Contractors have done a great job and done so quickly, have rebuilt the concrete pad under the extension and jacked it up and packed it with slate, I would think the corner of it dropped about an inch as it put the French doors out of alignment but all ok now.
It took over 13 ton of shingle and around 2 and a half ton of type 1, but they ran out and need another bulk bag to finish off next week. There were two old pipes that were broken that were going in to the sink hole, but looks like they were redundant. However, it dawned on me that several years ago I got a massive water bill about £700 on top of the monthly direct debit I had been paying, so contacted the water company. It turned out I had been paying for a meter reading from a meter that was about 50cm away from my actual meter that was hidden under a hedge.
It seemed that the meter that wasn’t mine had been flowing somewhere in my back garden and was an old meter disconnected to anything but still leaking water. I am starting to think that this is the probable likely cause of the problem, and the amount of rain following the dryish summer is what has caused it all to collapse.
Old 29-09-24, 06:20 PM   #11385
redtrummy
Great to know that it all looks positive now Rowdy, and a possible explanation to the cause. Water in or out can cause a lot of damage
Old 30-09-24, 06:16 PM   #11386
Sir Trev
Sir Trev's Avatar
My estimation of my Ford dealer has gone down yet again! Lady Poppy's car was in for a warranty fix a couple of weeks ago, door edge protector not retracting, nothing serious. Yesterday I sat in her car for the first time since then and I noticed the dealer had unplugged all the leads going to her dashcam, front and back. Power I can understand as they do ask you to deactivate cameras before you drop off and I forgot to let Lady P know this. Plugged them back in and it was dead...
Today I finally found the fusebox and a dangling spade connector wire clearly not standard labelled "grnd". Not only did they unplug the leads they disconnected the power supply! WTF?? Good job my car has the same dashcam, installed by the same company. Traced the fixing and replicated it in Lady P's car and bingo.
Guess who is NEVER going to use that dealer EVER again.
Old 30-09-24, 08:16 PM   #11387
garynortheast
garynortheast's Avatar
Just a mini GotD from me. I was helping to put Jan's new greenhouse up last week and I was putting the rubber beading on the frame by running my thumb along it. A small piece of sharp grit on the beading sliced open the pad on the end of my thumb. Painful enough, but the number of times I have knocked the end of my thumb since then is unbelievable.
Old 08-10-24, 07:03 PM   #11388
garynortheast
Grrrrripe of the day! I wish people would leave stuff alone when I set it up for them. Quick job this morning, plug and play powerline ethernet range extenders so that a client can use his laptop in his office upstairs, the other side of a thick stone wall from the router. Moved the router about three feet to a different window ledge so that the ethernet cable to the powerline plug wasn't stretched. All working perfectly when I left.
The woman of the house then decided that, because her ancient laptop froze when she tried to use it, it must be because the router was in a different place so she moved it back. Bingo! Her husband then had no internet. Half an hour on the phone at 8pm sorting it out for them. Sigh.....
Old 09-10-24, 09:15 AM   #11389
Luckypants
Luckypants's Avatar
I hope you charge for phone support. £50/hr seems the going rate....
Old 17-10-24, 01:49 PM   #11390
Luckypants
Luckypants's Avatar
Genuine gripe today..... toothache!
It started Tuesday night and was pretty sore yesterday but Ibuprofen kept on top of it but really sore this morning. Like a lot of folks I no longer have regular dentist so rang the local practice to see if I could be seen. They had an appointment over lunchtime so I took it. £180 and a tooth later, I hope this is sorted.
whats ur biggest gripe about the uk? kwak zzr Idle Banter 101 15-11-16 06:33 PM
heated grips gripe adw Bikes - Talk & Issues 8 12-05-10 02:48 PM
