Old 17-08-18, 04:05 PM   #1
hardhat_harry
Default SV650 Curvy no spark
Hi all
Bought a curvy none runner the other night. Started to fix it, no spark, swapped the whole loom (and sublooms) out as they had been butchered by the previous owner looking the fault, still faulty and swapped the cdi with a known good one, still no spark. Checked that the main wiring (i.e. not plugged in the carb heater circuit) all plugged in. Bike is turning over and fuses checked, petrol smell.......Anyone know of any gotcha's that could cause the no spark situation?
hardhat_harry is offline   Reply With Quote
Old 18-08-18, 02:21 PM   #2
hardhat_harry
Default Re: SV650 Curvy no spark
only 0.9v on the orange/ red wire the rest are ok
Old 18-08-18, 02:27 PM   #3
hardhat_harry
Are you sure about the orange / red wire, according to the wiring diagram it shorts with the black/ white earth wire in the ignition switch on ignition on?
Old 18-08-18, 03:19 PM   #4
hardhat_harry
Just measured the pulse coil resistance thats ok at 189 ohms
Old 18-08-18, 03:51 PM   #5
hardhat_harry
I took the ignitor off my race/ track SV which is working
Old 18-08-18, 04:08 PM   #6
hardhat_harry
Just measured 98 ohms and I also put my spare ignitor back on the track bike and that fired up fine.........hmmmm, interesting one this
Old 20-08-18, 08:08 PM   #7
hardhat_harry
Ok voltage measured and it was the same on the track bike
Earth on the CDI was measured as short to ground.
CDI from the road bike works on the track bike so CDI ok.
measured the wires to the pulse coil plug from CDI and they both read short.
When cranking over the voltage drops on each side of the pulse coil connections and restores when cranking stops
Old 21-08-18, 08:12 PM   #8
hardhat_harry
Check all the voltages on the CDI comparing to my track bike and they were the same which meant I had to take the side casing off the flywheel side to investigate further.
Found one of the magnets had come off and was killing the spark, removed that and fired it up.....
Success!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Now need to find a gasket and a cheap flywheel.
SV650 2000 no spark after pressure washing Forkliftfred SV Talk, Tuning & Tweaking 19 20-04-16 02:40 PM
SV650 K7 Twin Spark Bibio For Sale - SV's and SV related items 11 26-06-14 02:18 PM
2002 SV650 Curvy, no spark at either plug atassiedevil SV Talk, Tuning & Tweaking 5 03-03-14 10:04 AM
No spark - Curvy. joker650 SV Talk, Tuning & Tweaking 10 15-06-12 10:53 AM
spark plugs sv650 loneranger SV Talk, Tuning & Tweaking 11 19-09-07 10:02 PM
