Old 21-09-18, 01:29 PM   #1
Seeker
Seeker's Avatar
Default Painting a metal gate
My metal driveway gates need painting, they're about 125cm tall and have 12 vertical posts (1 cm sq) and a bit of a decorative curve at the top. The drive is 3m wide approx. I'm intending on using Hammerite, anyone know roughly how much paint I'll need?
There are many helpful on line tips on how to do it, but none give or suggest paint coverage. Hammerite comes in 250ml and 750ml sizes.
I did a rough and ready calc and estimated 1sq mtr. total for both gates.
OK, Hammerite say 5sq mtr/ltr.
Old 21-09-18, 02:41 PM   #2
Default Re: Painting a metal gate
having been a blacksmith.
dont use hammerite shizz. buy proper oil based gloss paint, it lasts a lot longer and is cheeper. thin the paint down and lay 2-3 coats on using a lambswool or a foam one designed for gloss paint mini roller (radiator) to paint the gate/railings as its easier and faster than a brush. put a dust sheet down as your going to get paint on the ground/path.
use a wire brush and a chip hammer to clean the old paint up. any large patches of paint needing repaired can be done using car body filler.
as for the amount then get a small pot and if you need more get another, also remember the thinners. non drip gloss is shizz as it sags under its own weight so best thin it down.
Old 22-09-18, 10:15 AM   #3
SV650rules
If you want it to last a long time with no maintenance then 2 pack epoxy paints are available - the bad news is that when you have mixed the paint you have a couple of hours or so to use it before it starts to harden in the mixing vessel - we used to use 2 pack to paint machine frames that were in a corrosive atmosphere. Temperature needs to be above 10 deg C (above 20 even better ) and dry weather for paint to be its best.
2016 SV650 AL7
Old 24-09-18, 10:22 AM   #4
timwilky
timwilky's Avatar
Starting point. Take them to your local sand blaster and get him to strip them back to shiny. Personally I would spray with 2 pack, but usual warnings apply. I have an air fed mask but you can use cartridge masks.
What about getting them powdercoated?
Not Grumpy, opinionated.
Crash at Barnards gate this morning TheRuffellator Thames Valley 0 24-01-14 01:37 PM
best metal to metal glue Wideboy Idle Banter 41 21-02-13 07:41 AM
Does anyone know any logic gate software... Stenno Idle Banter 4 18-01-13 10:39 PM
Painting anodised metal Geodude SV Talk, Tuning & Tweaking 3 08-03-11 05:14 PM
