05-04-10, 09:48 AM | #1 |
Removing choke retaining screw?
im in the process of sortin out my choke its not moving on the lever like it should. i,ve removed the cheesium screws as has been described in other threads, they were a b*tch to get out but with my trusty new screw extracter from B&Q they eventually came out along with most of the skin on one of my fingers, notr to worry i have nine more.
anyway may problem now is after removing the screw from the front carb the cable wont come out has anybody got any ideas or had the same problem. look forward to hereing the answers and thanx in advance mark |
05-04-10, 09:51 AM | #2 |
Re: bleeding for the cause !!!
it'll just be gummed up with cr ap-wiggle it till it comes out, give it a scoot with a cleaner to help it
05-04-10, 09:56 AM | #3 |
cheers husky will give it a go
05-04-10, 09:59 AM | #4 |
make sure your trying to remove the brass bit that sits in the carbs
05-04-10, 10:04 AM | #5 |
have got it out mate thanks a bit of leverage with screwdriver and it popped out was donderin thou can i spray wd40 into the card to clean the hole where it sits before i grease it all up and replace it.
05-04-10, 10:08 AM | #6 |
dip a rag in some petrol and give it a rub with that or use some carb cleaner spray
05-04-10, 10:10 AM | #7 |
sound cheers mate thanx for the help/advice
05-04-10, 04:50 PM | #8 |
well have got the choke plungers out cleaned them, greased them only round the springs is that right, have put it all back together and hey presto it works cant believe it i,m a mechanic now lol (is wish). anyway waiting to take it for a run just to make sure its ok but fingers crossed. my revs off the choke are around 1000 is that right or do i need to turn them a fraction as it still stalls from time to time.
05-04-10, 04:58 PM | #9 | |
05-04-10, 05:29 PM | #10 |
Re: Removing choke retaining screw?
how stiff should the knob be that you turn (no rude comments please lol), mines quite stiff am concerned about bustin it.
Stuck caliper retaining pin | beabert | SV Talk, Tuning & Tweaking | 8 | 26-10-09 11:47 AM |
removing a "scr*wed" screw from the top of the front brake rez | barwel1992 | SV Talk, Tuning & Tweaking | 28 | 22-10-09 08:28 AM |
Rear brake pad retaining pins. | mikebrooman | SV Talk, Tuning & Tweaking | 8 | 23-02-09 08:03 PM |
Pad retaining pins | dirtydog | For Sale - SV's and SV related items | 0 | 22-02-08 09:50 PM |
Rear Carburettor Choke Plunger Screw | fizzwheel | SV Talk, Tuning & Tweaking | 8 | 09-04-06 07:51 PM |
