Old 08-06-20, 05:40 PM   #11
tojo82
Default Re: K-tech front springs and spacer length
I've been a busy boy and bought a Zx14 shock today as well.
tojo82 is offline   Reply With Quote
Old 08-06-20, 05:50 PM   #12
Sean_Morgan
I found the zzr1400(zx14r) rear shock a massive improvement over stock
Sent from my SM-G960F using Tapatalk
Sean_Morgan is offline   Reply With Quote
Old 08-06-20, 06:00 PM   #13
tojo82
I'm 250lbs and have a top box with a work bag in. Very soon I should have a bike set up for my weight which would be nice
Old 09-06-20, 01:08 PM   #14
MattWll
Junior Member
No plumbing needed. Order the original and will not steam.
MattWll is offline   Reply With Quote
Old 13-06-20, 05:56 PM   #15
tojo82
Got the k-techs in as well as the Zx14 rear and all the sag set. It is a totally different animal now! It does t feel scary on corners anymore and doesn't chatter as you go straight on a slightly lumpy road. Wish I'd done it sooner!
Old 13-06-20, 08:09 PM   #16
Sean_Morgan
Good work fella
It's well worth the effort and the cost
Glad you're happy
Old 13-06-20, 10:17 PM   #17
tojo82
Thanks a lot
Old 14-06-20, 06:54 PM   #18
DamoK4
Was it easy enough of a DIY job? My suspension is absolutely terrible. I’ve been looking into spring rates and I am recommended .90 springs on racetech, i weigh about 13’5 without gear. Did you follow any particular guide? I’ve read and watched conflicting advice that’s all, it’s one job I’ve been reluctant to start
DamoK4 is offline   Reply With Quote
Old 17-06-20, 07:44 PM   #19
tojo82
Was easy mate. Crack the top nut whilst still on the bike. Take out spacer, washer and spring. Empty oil. Add 488ml of oil I did 15wt put spring, washer and spacer back in and screw back up. If you're doing seals as well it's more complex.
Old 18-06-20, 11:04 PM   #20
DamoK4
Oh right. I’ll have a go then. Nothing to lose 😀
Spacer size for RaceTech springs? loply SV Talk, Tuning & Tweaking 1 17-06-15 09:08 PM
Curvy swingarm bearing spacer length? Bibio SV Talk, Tuning & Tweaking 11 06-03-12 06:36 PM
K3 fork spacer length? RingDing SV Talk, Tuning & Tweaking 0 30-05-11 10:53 AM
GSXR 750 front end wheel spacer length? chakraist SV Talk, Tuning & Tweaking 3 28-09-09 05:45 PM
k5 fork spacer length? fast-lad SV Talk, Tuning & Tweaking 1 02-06-09 04:42 PM
