17-05-05, 12:26 PM | #31 |
I've been using a Caberg flip front for a year now and covered 15000 miles with no probs at all! It never mists, doesn't leak, gets used in really foul weather and always cleans up fine. And the inner visor is genius. I really like Caberg helmets and well worth the small price!
25-05-05, 01:58 PM | #32 |
Finally picked mine up, initial impressions are very good- easy to operate all the vents etc. with gloves on. V. noisey with vents open, but acceptable with them closed. Looks absolutely mint too. Loads of non-bikers at work spotted it and commented on it.
Has anyone here who has go one worked out how to fit the windstopper? I can see where it's meant to go, but the middle of the leather-like material gets caught on the chin vent switch and won't go in far enough. It is at the front/bottom of the helmet, at the bottom of the chin guard that this is meant to go, right? Any tips on fitting it? Cheers. |
25-05-05, 02:05 PM | #33 | |
HTH |
25-05-05, 02:11 PM | #34 |
Cheers Ed, when I was trying initially, I was trying to put the plastic bit in horizontally, rather than vertically in. I couldn't work out how to get it behind the ven switch, whereas it actually goes down the front. All in place now and looks like it should work well. Quick motorway blat to test it tonight.
Thanks again. |
25-05-05, 02:12 PM | #35 | |
25-05-05, 02:12 PM | #36 |
No problem.
25-05-05, 02:35 PM | #37 | |
25-05-05, 02:44 PM | #38 |
Mine fits just right the cut out bit in the middle leaves enough room for the switch to operate fine.
25-05-05, 02:54 PM | #39 | |
I'll have another play then . . |
25-05-05, 03:29 PM | #40 |
Okay had a play and found the reason I was having trouble was that the material on the windstopper thingy is out of true with the plastic. Mrs jonboy said "yes I can see that from here" from across the room.
So I've fiddled and pushed and prodded and it's just about acceptable and I can only just work the switch but not with the helmet on, but no great problem. However I think the amount of material is less than required to do it's job properly as it keeps slipping back over my chin. Mrs jonboy has agreed to machine an extension ( ) if I find something suitable. Customised, hey! . |
Caberg Trip | yorkie_chris | Helmets | 22 | 05-10-09 09:46 AM |
Caberg V2 | mac | Helmets | 17 | 07-01-07 06:58 AM |
Caberg 104 V2 Graphic | Grinch | Helmets | 11 | 07-09-06 08:47 PM |
caberg trip | markmoto | Helmets | 3 | 07-07-06 02:44 PM |
Caberg Brutus | Iansv | Helmets | 10 | 24-05-05 03:06 PM |
