Old 12-09-10, 04:14 PM   #1
Tess
Unhappy Replaced reg-rec, now won't turn over.
I've just replaced my reg rectifier and then fully charged the battery.
She fired up no problem and i took her out.
I went to go for a ride today, she started then just died and when i tried to restart her there was just a buzzing noise.
Now i'm not really that switched on when it comes to bikes does anyone have any idea what it might be???
Starter relay?
Old 12-09-10, 04:19 PM   #2
davepreston
Default Re: Help me bike won't start
sounds like a fecked battery, after the reg rec going the battery has been cooked now wont hold charge
Old 12-09-10, 04:23 PM   #3
davepreston
try to jump start it if that works the battery is cooked so replace
Old 12-09-10, 04:24 PM   #4
Tess
Do you thik that's what the buzzing noise is??
Old 12-09-10, 04:26 PM   #5
badsaboy
noise could be an electrical component(fuel pump, relay ect) which is getting enough charge to make a noise but not actually start the engine. Sounds strange but true. Like previous poster said - try to jump start
Old 12-09-10, 04:30 PM   #6
fizzwheel
fizzwheel's Avatar
Sounds like your battery is flat. Its quite common for the reg/rec to go and fry the battery when it does so.
The click / buzzing noise will be coming from a relay / solenoid that is trying to supply the feed to the starter motor.
Old 12-09-10, 04:32 PM   #7
Tess
Now i can hear in my mind what you're going to say when i ask How the hell do you jump start a bike??? I'm new to this biking stuff....
Old 12-09-10, 04:33 PM   #8
Tess
so what is the part that i will need to replace? The battery or the relay??
Old 12-09-10, 04:33 PM   #9
SuzukiNess
i'm sure electro will be along shortly to advise - he had loads of practice earlier today
Old 12-09-10, 04:34 PM   #10
davepreston
get jump leads and car , put red clipon to red clipon, black to black hit start button on bike
or put bike in second hold in clutch, stand on pegs and get some one to push bike (down hill recomended ) when up to speed release clutch and try to jump down onto seat to get more rear grip, if bike starts re engage clutch to stop you flying down road while reving engine
Replaced Release Screw shelleyamy SV Talk, Tuning & Tweaking 4 29-09-12 02:15 PM
Satnav for iPhone (Turn by Turn) Owenski Idle Banter 28 30-06-10 02:55 PM
SV Gone replaced with an RSV R Mille 04 danf1234 SV Talk, Tuning & Tweaking 11 17-08-07 07:21 AM
Battery Replaced chazzyb Ancillaries 4 06-09-06 12:07 PM
Replaced Oil, Plugs and Air filter. What next Diveboy SV Talk, Tuning & Tweaking 5 19-05-06 10:25 PM
