Old 25-11-20, 03:09 PM   #1
svenrico
svenrico's Avatar
Default engine bobbins
Just received some engine protector bobbins that mount with a bolt that goes through the engine. The original bolt is 12mm diameter and a fairly loose fit so easy to remove. The replacement bolt is only 10mm diameter so will be a looser fit. I presume there are projections on the engine that fit into the holes in the frame to take the weight of the engine ,otherwise the engine would be loose on the bolt ! Does anybody know if this is right ?
svenrico is offline   Reply With Quote
Old 25-11-20, 07:59 PM   #2
Default Re: engine bobbins
would help if you told us what year of bike you have, otherwise we will have to consult a crystal ball.
Old 25-11-20, 10:21 PM   #3
svenrico
svenrico's Avatar
Sorry, it is a 2020 SV650A. Evo Tech have actually confirmed it is a 11mm diameter spindle and when fitted and tightened there will be no issues.
Old 04-12-20, 04:57 PM   #4
Pilot
Junior Member
Tightened to how many ft.lbs. ?
Pilot is offline   Reply With Quote
Old 04-12-20, 08:28 PM   #5
svenrico
svenrico's Avatar
55Nm/40 ft.lbs
Crash bobbins SK3. str160 For Sale - SV's and SV related items 6 14-07-13 04:18 PM
Where to fit paddock bobbins? Goldy SV Talk, Tuning & Tweaking 5 15-03-11 06:01 PM
R&G Bobbins Noble Ox Stuff Wanted 8 24-06-10 08:16 PM
Levers, Bobbins, Bar End ibshort Stuff Wanted 4 18-03-09 09:01 PM
which engine oil, which brake oil, advice on crash bobbins Dennis SV Talk, Tuning & Tweaking 5 06-12-05 10:41 AM
