Old 22-02-17, 11:08 AM   #1
Adam Ef
Adam Ef's Avatar
Default Huggers to recommend / avoid?
Hi. I'm sure there are threads about this already but search is not turning up much for me apart from old for sale threads.
About to get a hugger for my K8 pointy and thought I'd see if anyone has any brand they'd recommend or anything to avoid? I was looking at the Red Fox ones through their site, probably along with a fender extender.
Is there anything to keep in mind such as brittle materials or makes to avoid? Ease of installation better with some than others?
All part of trying to make me less precious about my SV and get out and ride it more not worrying about water and dirt.
Cheers.
Old 22-02-17, 12:20 PM   #2
aesmith
Default Re: Huggers to recommend / avoid?
My old bike (pointy K6) has a Red Fox hugger. Down side is that it sits on top of the swinging arm at the front if you understand what I mean, rather than extending down below. It's also now split at the chain guard portion, but that could be abuse on my part.
The one on the new bike extends below the swinging arm, but I don't think there's a maker's mark on it.
Old 22-02-17, 05:37 PM   #3
Nutsinatin
Nutsinatin's Avatar
I've used Pyramid huggers and fender extenders (pyramid buy the extenders from the same company that skidmarx do) on both my bikes and they've been fine.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 22-02-17, 06:00 PM   #4
SV650rules
Fitted pyramid 'carbon fibre' look hugger on my AL7 and was easy to fit and looks pretty cool.
front fenda extender also good addition to SV
2016 SV650 AL7
Old 22-02-17, 06:37 PM   #5
Toooldtodie
Toooldtodie's Avatar
My Powerbronze hugger has corrosion welded itself to the bike, but is still in one piece at least. To remove it I will have to drill the fasteners out...
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 23-02-17, 12:48 AM   #6
dont bother. huggers are only good if mud gets on the shock, well the K8 already has a flap that extends from the tool box so no mud gets on the shock.
underside of seat.. ermm well thats what the big bit of black plastic is for.
same goes for those stupid tail tidy things.. waste of bloody time and money if you ask me.
waste of money. spend it on service items instead.
front crap flap YES those are a must on an SV.
Old 23-02-17, 10:35 AM   #7
Adam Ef
Adam Ef's Avatar
Cheers. I did wonder why it was needed when the flap is already where it would be!
The tail tidy was fitted by the previous owner along with all bolts replaced with red anodized ones! He wasted his money so I don't have to !
Will get the front fender extender for now and avoid the extra cost of the rear. £95 saved, cheers !
Old 23-02-17, 11:04 AM   #8
L3nny
L3nny's Avatar
Vanity is a reason. Might not be enough of a reason for you but tarts like me are kept awake at night by the thought of a snow plow on the back of a bike.
2015 GS 1200 Adventure
Old 23-02-17, 12:32 PM   #9
pookie
pookie's Avatar
Just put a hugger on mine as I saw the mess left behind on the rear swingarm and underside of the exhaust after a wet ride. I'm hoping for less next time I'm out. This should allow me to sleep at night when I dont jet wash after a ride.
Have you seen the cack on the underside of a the snow plough and numberplate yuk
Old 25-02-17, 04:26 PM   #10
aesmith
The one on the new bike is Pyramid. It continues down past the swinging arm at the front, which is how I prefer it. The disadvantage is it fixes on the right hand side with a rather naff clamp around the swinging arm. I decided I couldn't bear that so I've made a bracket to sit on top of the arm secured under the brake hose guide.
K4-6 huggers that actually fit! Gazza77 SV Talk, Tuning & Tweaking 0 22-07-06 01:21 PM
Huggers - Where did you get yours from fizzwheel Bikes - Talk & Issues 15 10-05-06 01:42 PM
Huggers for K5 Gazza77 SV Talk, Tuning & Tweaking 10 21-04-06 05:06 AM
Huggers Ward8124 Bikes - Talk & Issues 3 10-04-06 09:03 AM
Huggers fraser01 Bodywork 17 12-10-04 10:51 AM
