Old 13-08-17, 06:27 PM   #21
R1ffR4ff
R1ffR4ff's Avatar
Default Re: What is this and how do I make one...
Originally Posted by andy650 View Post
The curvy SV reg/rec is known to be rubbish. It is old tech and gets no cooling, a recipe for disaster.
I replaced mine with a MOSFET unit, far better without doubt.
The SV is a very hard bike to bump start, only attempt with someone else pushing, even then you will struggle.
There is nothing wrong with the Stock Curvy R/Rs.Mine is stock and in it's 19th year.I have a stock R/R on a Honda CX500 that is now in it's 38th year.
As for ,"Old Technology" Mosfets were invented in 1959
Old 13-08-17, 06:29 PM   #22
R1ffR4ff
R1ffR4ff's Avatar
Originally Posted by Chris_SVS View Post
K3 does
Originally Posted by punyXpress View Post
Curvy doesn't have a pump?
The Curvy has a Vacuum operated/assisted pump and is driven from the rear cylinder carb balance spigot or at least my 1999 does
Old 13-08-17, 06:49 PM   #23
Chris_SVS
Chris_SVS's Avatar
Chris_SVS is offline   Reply With Quote
Old 13-08-17, 07:50 PM   #24
andy650
Many curvy owners would disagree with that statement. You have been lucky.
The biggest problem is lack of cooling, there is nothing wrong with the old style RR's, apart from the heat they produce. MOSFET runs cooler, hence the lack of cooling on the SV is less of a problem.
Maybe MOSFETs were invented in 1959, but they have only become common on bikes in recent years to my knowledge, presumably as the costs fell?
I went through 3 standard RR's, then I gave up and went MOSFET.
I have non MOSFET RR's on all my other bikes, none have ever caused a problem, but they are all cooled far better than than SV RR.
andy650 is offline   Reply With Quote
Old 13-08-17, 07:56 PM   #25
R1ffR4ff
R1ffR4ff's Avatar
I've not been lucky.I've been vigilant and as for,"Many" that may mean many have been misled and reading complaints/failures from the Internet is not a valid,"Real world" testament as there are countless hundreds of thousands on Motorcycles using stand R/Rs with no problems including Curvy SV650s.You rarely see a post saying,"My R/R is working perfectly
I don't disagree that the Mosfet design is superior and if some one has had problems it may well be a cure but it by no means a common problem IMHO just a commonly,"Highlighted" one.
Old 13-08-17, 08:10 PM   #26
andy650
How can you be vigilant with a RR? It either works properly or it doesn't, and you cant do anything to service it.
When my third one failed, I bypassed all wiring back to battery, and spent the extra £30 or so on the cooler running RR to be sure. It charges to 14.3 on the nail all the time, the old one (with old wiring) was never so perfect, even when new.
Old 14-08-17, 08:38 PM   #27
NTECUK
NTECUK's Avatar
Calm down.
It all came about because of the Mazda MX-5 .
Not repeated faults on the curvy....
Old 15-08-17, 08:43 AM   #28
johnnyrod
johnnyrod's Avatar
2 for me (including one that ruined a holiday with the ladz) then I bought an Electrex MOSFET one. Unlike the 1970s there's no guarantee the Suzuki one will give up, but it's by no means indestructible. My SV is also 1999 so has had plenty of years for stuff to wear out or pack up.
Old 15-08-17, 10:51 AM   #29
R1ffR4ff
R1ffR4ff's Avatar
You are correct in that as a solid state unit they are unserviceable however the connectors leading to them are.
Electronic devices are not,"Pass/Fail" devices.They can partially fail just like electromechanical and mechanical devices.
In the case of the Regulator/Rectifiers components inside can degrade overtime leading to on the Regulator side an increase in Voltage at the battery to a point where it ruins the battery.
On the Rectifier side any one of the Diamond formation diodes can partially fail and cause AC current through to the battery.This again will destroy a DC battery.
The most common cause of these failures is lack of maintenance of the Electrical connectors,especially the larger one that carries the three Yellow HT wires.
There is a lot of current passed through this connector and if the pins and sockets start to corrode the resistance at that point will increase.This will normally lead to other parts of the charging system trying to compensate and work harder to a point where they are taken out-of-spec.The increased resistance also has been known to melt the large connector and then the Stator HT wires short and the high current from the Stator feeds back on itself and burns out the coils.
There's plenty of pictures and posts on the net when this has happened and it's not nice and potentially lethal in the case of an Automotive fire.
Whatever unit you use please make sure that the Large connector pins and sockets are free of corrosion and electrically and physically secure.I use ACF50
http://www.acf-50.co.uk/motorcycle.htm
on ALL my electrical connections and for good measure if you ride a lot in the rain you can also double secure using Dielectric grease around the connector.
https://tinyurl.com/y9m3l4xk
Old 15-08-17, 05:27 PM   #30
SV650rules
RiffR4ff is spot on, if you don't look after the RR connectors and they get corroded you would be surprised how much heat can be produced by the high resistance - this is heat produced OUTSIDE the RR but conducted inside the RR through the connector, the heatsink on the RR has to try to get rid of it, something it was not designed to do - so the RR gets much hotter than it should and the heat causes thermal runaway in the diodes - meltdown.
Gold plated connectors are actually higher resistance than silver or nickel ones initially, but because the gold does not oxidize the connections maintain a stable resistance throughout their life, whereas other platings oxidize and increase in resistance, and it is a vicious circle, the hotter they get the more they oxidize, the more they oxidize the hotter they get...................................
If you can seal the connectors from oxygen and water (water is a source of oxygen) you should not have a problem. Petroleum free silicone grease (rubber friendly) is good, ACF-50 also OK.
2016 SV650 AL7
What will it make? andrewsmith Idle Banter 30 16-11-13 08:44 PM
Whats needed to make a carby 650 make 72bhp? Sy-superfly SV Talk, Tuning & Tweaking 8 12-09-11 11:08 AM
Tetley make tea bags make... Bear Soho Massive 7 14-03-11 08:48 PM
Does Anyone Make These? I'm_a_Newbie Bikes - Talk & Issues 10 27-10-10 05:30 PM
Make up artist of make up artists... noisie SV Talk, Tuning & Tweaking 0 03-10-07 05:22 PM
