Old 04-10-18, 11:10 AM   #11
Default Re: Factory Pro Velocity stacks
The only way to tell if these mods work, is to have the bike on a Dyno and see if they make any difference once fitted.
completely agree but then you wasting more money
Old 04-10-18, 11:38 AM   #12
Craig380
These arrived this morning, so I'll get them fitted at the weekend and see what I think. They're the stock airbox inlet rubbers from a 2010 V-Strom:
Old 07-10-18, 07:57 PM   #13
Craig380
I fitted the DL stacks. It was straightforward apart from about 15 minutes of wiggling, tugging and twisting to get them mounted properly: I inserted them up and through from the underside of the airbox. A trace of red rubber grease and a bit of swearing helped.
I did about 250 miles over the weekend, and the difference is noticeable. The throttle response and pick-up in the 3,000 - 7,500rpm is sharper and stronger, especially in the first half of the twistgrip movement. A couple of times I was behind cars that were travelling at a steady 65 - 70, cruising on a light throttle, and when I gave it a little tweak of the grip to overtake being sure I must be in 5th because of the ease which I punched past them ... only to find I was actually in 6th all along.
They suit my riding style, as I hardly ever go over 8,500/9,000rpm and very rarely use more than half throttle (the bike is standard with standard gearing etc apart from a SV1000 airbox snorkel and the new stacks).
They're definitely staying in.
M4 Carbon High mount Full system, Power Commander 3 (mapped) and Factory Pro Velocity Stacks Vinc For Sale - SV's and SV related items 25 22-04-14 08:34 AM
Velocity stacks lawson17 Stuff Wanted 0 14-08-13 10:25 PM
velocity stacks antony Stuff Wanted 2 10-05-10 03:17 PM
35/70 Velocity stacks rossinio Stuff Wanted 6 07-04-10 01:12 PM
Velocity stacks tapemonkey SV Talk, Tuning & Tweaking 11 20-02-07 05:26 PM
