Old 25-12-17, 09:37 PM   #11
SV650rules
Default Re: Faulty ceiling light query
you need something like this - if you know manufacturer of your light unit may be best to contact them for correct unit.
https://www.ebay.co.uk/b/Home-Lighti...05/bn_55178118
2016 SV650 AL7
Old 27-12-17, 06:24 PM   #12
SV650rules
The only other thing may be the switch contacts or mechanism failing, may be worth trying a new switch as the cheapest option.
2016 SV650 AL7
Old 29-12-17, 12:25 AM   #13
Heorot
Yep, that's the item I was talking about. The old one should have the voltage and amperage on it. As I stated before, cheap to replace.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 29-12-17, 07:31 AM   #14
Littlepeahead
Littlepeahead's Avatar
My bro in law is a qualified electrician although he modestly does smoke alarms in office blocks but I might get him to help me take it apart. I reckon the little white box is the issue here.
Sent from my SM-G930F using Tapatalk
Old 31-12-17, 09:09 PM   #15
ethariel
ethariel's Avatar
Yep if you are getting that buzz and it wont work for a while after being switched off, sounds (as above) like the LED Driver is shot. Simply check the spec of the current one and get a 'decent' replacement off ebay or amazon, don't just buy the cheapest, Mean Well are a reasonably good domestic supplier but not the cheapest.
ethariel is offline   Reply With Quote
Restricted ECU rev ceiling? Rog4747 SV Talk, Tuning & Tweaking 6 03-10-11 01:46 PM
MOT due, brake light query cF^ Bikes - Talk & Issues 5 09-07-10 05:47 PM
Fuel light query. scottjames SV Talk, Tuning & Tweaking 10 28-02-10 02:35 PM
faulty rear brake light ntorrens SV Talk, Tuning & Tweaking 3 28-05-09 11:53 AM
query on connecting new intercom to tail light circuit Johnsilver SV Talk, Tuning & Tweaking 3 28-05-05 04:57 PM
