Old 05-04-09, 09:15 PM   #1
curium
Default Best way to clean up brake pistons?
The brake pad pins on my Suzuki SV650SK6 were seized in so I was unable to replace the pads. I've ended up taken the callipers off and this has enabled me to get the pins free. While they're off I've decided to replace the seals and give the pistons a clean up.
Two things, anyone know where you can buy red rubber grease in London to coat the pistons and slider pins. Secondly, the Haynes reckons that the pistons must be replaced if any surface defects are present but the pistons were not leaking so I want advice on how best to clean them up.
Here is a photo
So far I've been using a non-scratch nylon scour pad but this is the best I've gotten. I think it is unrealistic for the pistons to be totally free of surface defects so I'm not keen on replacing them.
Old 05-04-09, 09:19 PM   #2
arcdef
Default Re: Best way to clean up pistons?
i was told to use metal polish on mine.
Old 05-04-09, 09:23 PM   #3
Stu
Trinity
Stu's Avatar
I was told (by S..S....) to use the cheapest supermarket own brand cream cleaner.
I was also told by someone else that you don't put any RRG on the pistons, only the seals. You must not get any RRG inside the hydraulic brake system i.e. inside the calipers. You should lube the pistons with brake fluid before inserting
Where are your other 8 pistons?
Old 05-04-09, 09:23 PM   #4
Miles
Something like brake cleaner / parafin to clean the bulk of it off then autosol would work a treat at getting them spotless.
Old 05-04-09, 09:44 PM   #5
curium
cheers fellas!
Old 05-04-09, 11:09 PM   #6
zadar
yep, best way.
Old 06-04-09, 10:37 AM   #7
breakz187
Default Re: Best way to clean up brake pistons?
I used a bit of steel wool yesterday on my fronts.
I tried brake cleaner and tissue, but it didnt shift the dirty/rust type corrosion.
I was worried about using steel wool but it didnt damage the surface and was smooth as when i used my lip to test
breakz187 is offline   Reply With Quote
Old 06-04-09, 01:06 PM   #8
skyline
I'd heard it was a bad idea to lube the pistons with brake fluid as it crystallises and then ruins the seals?
I've probably got this wrong tho...
Old 06-04-09, 02:08 PM   #9
Some RRG is gonna end up inside the hydraulics whatever you do. All I do is push the seals down into their grooves to remove excess grease so there isn't much of it in there.
I do not use brake fluid on the pistons. I wipe a small amount of RRG around the walls. The seals will collect nearly all of this.
I do not think it is a good idea to put brake fluid anywhere except into the reservoir, when exposed to air and water it turns into a wierd crystalline solid, this will cause dust seals to stick to pistons quickly in use, especially in winter.
Might be OK to use when the seals have been RRG'd, but I don't see it doing any good either. And I don't like getting brake fluid on my fingers, so I don't bother.
Old 06-04-09, 02:09 PM   #10
Yes and a scotchbrite pad
Brake Pistons? vardypeeps SV Talk, Tuning & Tweaking 4 29-08-08 12:12 PM
Any QUICK way of getting brake pistons to retract? goof SV Talk, Tuning & Tweaking 8 24-06-06 07:10 PM
scaring on brake pistons huge SV Talk, Tuning & Tweaking 2 13-01-06 04:32 PM
new brake pistons and seals. where from? raymond smith SV Talk, Tuning & Tweaking 2 30-04-05 09:24 PM
Rear Brake Pistons JMCHITTOCK SV Talk, Tuning & Tweaking 8 22-02-05 09:23 AM
