Old 26-02-20, 08:29 AM   #1
gadget
Default 99 curvy vacuum/ fuel line I'd size
Hey all, I'm going to do the extended vac line mod for future carb sync jobs and i am trying to get a definitive answer as to the exact ID size of hose to use, can anyone tell me exactly what size hose to buy for this job? as iv'e read soooooo many conflicting threads 'n' answers it's getting confusing. Thanks in advance.
gadget is offline   Reply With Quote
Old 26-02-20, 01:57 PM   #2
Default Re: 99 curvy vacuum/ fuel line I'd size
Ask Biblio he made them up for us
Old 26-02-20, 08:19 PM   #3
gadget
Any further info on the I.D. size peeps? Ideally would like to buy some hose tomorrow if I can get the info on size.
Old 27-02-20, 08:55 AM   #4
Seeker
Seeker's Avatar
I don't know the answer, sorry. However, there are a few sizes of hose on the carbs, couldn't you try different pieces till you get one that fits and then use this diagram:
https://www.fowlersparts.co.uk/parts...retor-fittings
to check the size. The sizes are marked in mm.
Another suggestion - if you look at (org member) Tamsen's carb balancing video :https://www.youtube.com/watch?v=N7U5SwoOJto at 1min 56 secs she pulls off the vac tube to the fuel valve (on tank) - you could measure that since it's relatively accessible.
2016 SV650AL7
2023 GSX-8S
Fuel line size? Curvy. Aligowers SV Talk, Tuning & Tweaking 2 05-10-14 08:35 PM
Curvy fuel sender unit O ring size? fchat63 SV Talk, Tuning & Tweaking 2 06-06-14 09:52 AM
curvy fuel line bleed jimathyy SV Talk, Tuning & Tweaking 13 04-05-11 08:46 AM
Why is the fuel line so short (curvy) ? no_akira SV Talk, Tuning & Tweaking 1 11-10-09 08:10 PM
Fuel line size svrash SV Talk, Tuning & Tweaking 1 29-08-06 07:02 PM
