21-12-17, 10:42 PM | #11 |
Re: Curvy Cold Starting Needs Running Start
Hey guys. Been a while...I came off on that weekend before I had the chance to try everything! Sad times as am still waiting for the shifter to arrive from America..
But here is the interesting part... Before I came off, I had the chance to check the airbox (thought would start with the easy stuff before getting to electrics). And after removing it I find petrol (edit: could have been oil...forgotten by now!!) inside. This could explain the choke issue right? But how could it have gotten in there??! So i cleaned out the liquid from the airbox and run a bit of fuel system cleaner through it and rode out to my friend’s. The next morning it had trouble starting again but did eventually, I rode for 5 mins and came off. Took it back to his where it is now. Came back a week later to have a look at it and it started first time without problems! I think this is because the connection in the starter motor jolted back into place or something?? But now the exhaust sounds different...more muted and not as crisp and raspy as before and backfires every now and then on idle. Yet another mystery to solve. To sum up: I think Biggles is right in that there were/are two problems: starter motor and choke. The choke issue seems to be something to do with the presence of petrol/oil in the airbox (is this what running rich means?). Ordered a new filter. But how did it get there? What’s the cause? The starter motor issue (as my car mechanic friend explained) could be something to do with worn out brushes which causes motor to short (im paraphrasing but he seemed to be sure of it as soon as I described the symptoms). The fall may have shifter the position of the brushes which is why it now starts well again. But have Ordered the back part of the starter motor to replace. If these fail, will get to examining the electrics. But now, the issue of the backfiring...does anyone have any ideas? |
22-12-17, 11:02 AM | #12 | |
The plugs were changed not a week before the crash. Brand spanking new. No I put the old filter back in prior to riding it. Sent from my iPhone using Tapatalk |
24-12-17, 10:21 PM | #13 |
Hmm my money on the backfiring - which I'm guessing is more of a pop than a gunshot - is a stuck choke and it's all running rich. Nothing to do with oil in the airbox - mine gets this now and again if I cane it, it builds up slowly really. You need to check the cable for kinks and make sure it has enough slack in it. Also check where it splits as this little box is easy to break. You could do with getting the plungers out and checking for rust etc. build-up on the seats. If you follow the cables to the two carbs, you need to undo the single screw of the retaining plate, and carefully pull out the plunger - if in doubt, pull the choke lever right back first and nothing will fall off. Check the recess for crud, repeat for the other carb. The screws and be stuck fast so use a good-fitting screwdriver and try not to chew them.
28-04-18, 03:44 PM | #14 |
Hey guys. Been a while. A lot has happened since...
After a difficult time starting on a particularly cold morning, got it going but noticed the gargling backfire was worse than usual. Cranked up the choke. After a few hundred metres, pulling up to a traffic light, noticed the revs dropping and the gargling g continued. Upped the choke. On the dual carriage, plodding at about 70 to warm it up. Traffic ahead, rolling off the throttle and when at about 2-3k revs, it shuts down completely. Would not start up again while still coasting. So I coast off the side off the curb (lucky was by a stretch of curb with a parallel road rather than just a wall). Trying to start with no such luck. This time not even a hiss, click, fizz, bang, crackle or pop...nada. Other electrics showing signs of life though with the lights, hi beams, indicators, horn as well I think. Just no ignition. Left it there and took the bus to work. Friend picked it up with his van in the eve. By the tine get to mine, van stank of petrol. Could see petrol on the right side of the engine, looks line came form front carb. Figured it was a blocked carb so I stripped them off the bike and cleaned them myself, getting all the jets, float needle and seats etc...the whole shebang. Also, as someone had suggested, took off the starter motor and replaced the brushes. When the weather picked up, got to work...connected the carbs back up, checked and lubed the throttle and choke cables as you guys suggested, inspected the electrics as much as was easily accessible, reinstated the starter motor, charged the battery. Started right away. But then it didn’t, so replaced the starter solenoid, same story. Then done what I should have checked first, the clutch starter switch, cleaned it and that seemed to have done the trick. Started perfectly and ran flawlessly...no leaks. Gave it a thorough clean, cleaned and lubed the chain, changed the oil. Next day was ecstatic to be riding to work again. In the morning had a tiny hitch when starting but nothing major and started pretty much right away. Got to work. 8 hours later thought, the difficult starting began again. A minute of struggling, got it going. Next morning much worse. Took 5 minutes to get it turning over (see vids at below link). Basically same problem began. Oh and some petrol and oil comes out of then left side hole in the engine (rear plug drain hole??) when starting only. Got worse after work. The following night I decided to take off the battery to charge it in case the problem was with the rectifier (nope. Battery was fully charged). There was a strong smell of petrol and having a look (the first two vids at the link) I could see the petrol stains on the left side of the engine and some deeper inside. So basically am now even more lost than ever. The difficulty starting seems to be inherently linked to the petrol leak. But why it started leaking again is beyond me. Only took two trips for it to come back. What could it be?? https://www.icloud.com/sharedalbum/#B0BJ0DiRHGNU4RA (the videos are in reverse chronological order) Sent from my iPhone using Tapatalk Last edited by machulnyy; 28-04-18 at 03:50 PM. |
29-04-18, 02:05 PM | #15 | |
You have no idea. Was verging on tears when the leak returned . Right. So I’ve ordered a rebuild kit for each carb. Once they arrive, will take the carbs off and rebuild. Will then test the integrity by blowing into and adjusting the float to see if it shuts off the airflow. (Will check the height of the tab in the manual) Will then look for how to test the fuel pump and valve in the manual. Will report back once have tried, unless anyone has any other ideas I could try while the carbs will be off?? Appreciate all your help. Sent from my iPhone using Tapatalk |
30-04-18, 05:30 PM | #16 |
whats rining my alarm bells is:
1. sidestand switch or clutch switch is fubar. when these go you can usually start the bike when the sidestand is up or down depending on what mode the switch is stuck at. problem is the SV has a "check" built into the ECU so a fubar switch will stop the bike from starting. sometimes giving the bike a push start will "jiggle" the switch enough to let the bike start. 2. smoke from the drain hole, thats mousture so water is getting into the plugs. if water is getting into the plugs it will trap itself under the plug cap causing arching and eventually break down the plug insulation. |
10-05-18, 09:45 AM | #17 | |
Not really under pressure, just kind of seeps out. Wasn’t a windy day. Haven’t cleaned out yet...didn’t know I could/ should. Will do this eve along with checking the seating of the spark pluga! Sent from my iPhone using Tapatalk |
10-05-18, 09:46 AM | #18 | |
Not really under pressure, just kind of seeps out. Wasn’t a windy day. Haven’t cleaned out yet...didn’t know I could/ should. Will do this eve along with checking the seating of the spark plugs! Sent from my iPhone using Tapatalk |
10-05-18, 09:52 AM | #19 | |
Ahh this so sounds like the problem! Just went down to smell the oil gasket and it smells of petrol! Hydrolocked Now to find the cause of the leak, right? First will check the fuel pump/ petcock. Then the carbs...have received the restore kits last week Sent from my iPhone using Tapatalk |
10-05-18, 09:57 AM | #20 | |
Hmm...good shout. the switches could be a culprit also as I did initially think it could have been the clutch switch..didn’t think of the stand one. Is there any way of telling without replacing?...will check these once I’ve run through the hydrolock symptom checklist. The petrol smell from the oil gasket is a strong indicator that that is the problem though I reckon Sent from my iPhone using Tapatalk Last edited by machulnyy; 10-05-18 at 09:58 AM. |
Misfire on cold start - Curvy. | shane1964 | SV Talk, Tuning & Tweaking | 11 | 14-10-13 06:40 PM |
Curvy difficult starting in cold weather. | RobG650 | SV Talk, Tuning & Tweaking | 12 | 17-12-12 09:54 PM |
Curvy cold starting trouble. | Goodfella | SV Talk, Tuning & Tweaking | 21 | 09-12-12 08:58 AM |
Curvy cold starting? | JonGeorge | SV Talk, Tuning & Tweaking | 13 | 29-09-12 02:08 PM |
Cold starting curvy | boot | Bikes - Talk & Issues | 21 | 27-12-09 08:35 PM |
