Old 13-05-18, 12:04 PM   #11
netsurfer
Default Re: K1 carb refit after 4 years in storage
Originally Posted by Seeker View Post
Regarding the seals - I just cannot remember what they look like - whether they are a regular oil seal or an O ring. If an oil seal type - they tend to be standard sizes so any oil seal seller would be able to help if you take the carb to them.
This infuriating link shows you everything (on a BDST carb) except part numbers:
http://www.litetek.co/Guide_MikuniBD...ShaftSeal.html
Thanks! I had a nosey around on the litetek site and found on the detailed rebuild guide that the carb is also used on a Yamaha FZR-400RR so went into this section on their site and found the Yamaha part number! 256-14997-00
So, if it comes to needing seals, i'll add them to my motorcyclespareparts order that I need to place for some other genuine items.
Pete
netsurfer is offline   Reply With Quote
Old 13-05-18, 12:05 PM   #12
R1ffR4ff
R1ffR4ff's Avatar
Pete
That's great work and well worth knowing
Old 16-05-18, 08:39 PM   #13
netsurfer
Slowly getting there, carbs refitted but waiting for some other bits before I try to fire the old girl up.
Meanwhile I’ve been trying to diagnose a sticky throttle and while I think I’ve sorted it (cable adjustment) I realise I have routed the idle adjust cable incorrectly. On closer inspection I think I may have also routed the rear choke cable incorrectly too.
Can anyone confirm does it go above or below the frame crossmember that is between the two carbs?
Currently I have it sandwiched between the carb frame and the crossmember but it looks like it might wear over time.
Trying to attach a photo to help explain.
Old 22-05-18, 10:56 PM   #14
netsurfer
Decided to remove the carbs and refit the cable below the frame, glad I did - the choke cables were partially seized allowing only about 30% travel. All freed up now, waiting for new choke O-rings before refitting.
Anyone used motorcyclespareparts.eu before? Just wondering how quick the delivery is
OMO: Bathroom refit help! Brettus Idle Banter 27 11-07-12 07:22 PM
Can't refit standard exhaust! carpet monster SV Talk, Tuning & Tweaking 5 26-02-12 07:57 PM
Curvy projector headlamp refit. markc123 SV Talk, Tuning & Tweaking 5 12-02-12 03:54 PM
Grabrail removal - how does the seat refit? L3nny SV Talk, Tuning & Tweaking 32 08-08-09 01:32 PM
standard exhaust refit on 99-2002 99-2002love SV Talk, Tuning & Tweaking 13 08-03-09 11:26 AM
