Old 20-05-18, 06:23 PM   #1
BillySV
Default 2001 SV650S to N - Trail Tech: Wiring Question
Hey forum!
I'm pretty sure this may have been asked before, but I am not the best at searching and may have passed over it. Anyway, here is my situation.
I'm trying to wire in a Trail Tech Vapor gauge to the stock wiring harness. I'm not going to be using a dashboard right now, but I may or may not get one in the future (still thinking about it). I found a diagram online that looks like it basically combines different accessory wires to the power input on the gauge.
http://farm9.staticflickr.com/8452/7...824305eb1a.jpg
Would this actually cause a short to happen? Is it possible to just combine several wires into the power wiring on the Vapor gauge? I'm kind of confused by the instructions from the gauge as well, but I'll go over them again and see if anything kind of sticks out to me.
Old 20-05-18, 07:12 PM   #2
BillySV
Default Re: 2001 SV650S to N - Trail Tech: Wiring Question
Originally Posted by Seeker View Post
What could possibly go wrong?
The scientific way would to be match the sv schematic to the Vapor, less scientific would be to temporarily attach each lead with a very low amp fuse.
I did find this:
http://www.svrider.com/forum/showthread.php?t=53191
but since it's 39 pages long, I'll leave that with you. Good luck.
I've been cruising through those pages and that's where I found a couple of diagrams. I feel like it is really easy, but I am just not understanding how to get multiple accessories wires (blinkers, coolant temp, speed sensor) to go through one power cable and ground cable.
Old 21-05-18, 02:01 PM   #3
you basically either daisy chain from and to each connector or you solder them all to one live or use a bus bar connector.
Wiring up Vapour Trail to 99 SV650 Badeye Bikes - Talk & Issues 0 06-01-15 09:36 AM
trail tech vector missy locks SV Talk, Tuning & Tweaking 3 20-09-10 05:36 PM
trail tech vapor power questions barwel1992 SV Talk, Tuning & Tweaking 17 17-06-10 11:36 AM
Trail tech vapor - Help barwel1992 SV Talk, Tuning & Tweaking 6 26-05-10 10:22 AM
2001 sv650s question... BRizzle SV Talk, Tuning & Tweaking 17 18-04-06 09:52 PM
